Page 13 of 33 FirstFirst ... 34567891011121314151617181920212223 ... LastLast
Results 121 to 130 of 328
Thread: Fusion Brain Version 6 -- Beta Testing
  1. #121
    Variable Bitrate rEegLer's Avatar
    Jul 2008
    Mechanicsburg, PA
    I'm updating now. Only security updates for .NET though, nothing big. I have 1.1,2s p2, 3 sp2, 3.5 SPI, 4 Client, 4 Extended, 4 multi-targeting pack.
    If I take the gui stuff out:
    Code:
    <FuseGL_GUI_Settings>
        <setting type="size" name="gui_size" width="274" height="600" />
        <setting type="int" gui_border_thickness="1" />
        <setting type="colour" gui_border_colour="85,85,85" />
    </FuseGL_GUI_Settings>
    it works fine.
    Even having the <FuseGL_GUI_Settings> </FuseGL_GUI_Settings> stops it from running.
    Graphics aside (as it's NOT terribly important), do you have an example of logic with analog inputs?
    Love
  2. #122
    Jul 2008
    Mechanicsburg, PA
    Updated and still nothing.
    Love
  3. #123
    Mar 2006
    Colorado, but Canadian!
    Sorry been crazy busy. Here is a quick code sample:
    Code:
    using System;
    using System.Collections.Generic;
    using FB_USB_2011;
    using FuseGL.GUI.Text;
    using FuseGL.Logic;
    namespace FuseGL_SomeNamespace
        class SomeClass
            public object SetupAnalogueInputToDoSomething(FB_Monitor.AnalogueInputPort _port)
                _port.AnalogueInputDataReceivedEvent += new FB_Monitor.AnalogueInputPort.AnalogueInputDataReceived(doSomethingEvent);
                return null;
            void doSomethingEvent(FB_Monitor.AnalogueInputPort _port)
                if(_port.Port == 0)
                    if(_port.Value < 1.0)
                        // Do Something
                    else if (1.0 < _port.Value && _port.Value < 2.0)
                        // Do Something Else
                    else if (2.0 < _port.Value && _port.Value < 3.0)
                    else if (3.0 < _port.Value && _port.Value <= 3.3)
    1.9in x 2.9in -- 47mm x 73mm
  4. #124
    Jul 2008
    Mechanicsburg, PA
    Awesome. Thanks.
    Love
  5. #125
    Jul 2008
    Mechanicsburg, PA
    And the config file would look like this?:
    Code:
    <FuseGL_User_Settings>
      <Startup_Events>
        <events>
          <startup action="FuseGL.ExecuteCode" inputArgs="Logic.cs;FuseGL_Logic.CarPC;doSomethingEvent;{FB.AnalogueInput(0.0)};"/>
        </events>
      </Startup_Events>
    </FuseGL_User_Settings>
    That doesn't work for me.
    Also, is startup events where you place code for things that you want to be default on?
  6. #126
    Mar 2006
    Quote Originally Posted by rEegLer View Post
    Code:
      <Startup_Events>
        <events>
        </events>
      </Startup_Events>
    Yes assuming you saved the file as Logic.cs in your root directory and changed the name of the namespace and class. By doesn't work do you mean crash? If so then I need a trace file and I also need to know which version you are running since you seem to experience things that have been addressed in updates some time ago. The code I posted doesn't actually do anything, it just captures the port values so you can do something with them. So you can put whatever you want in there.
    It is where you place things you want to have happen on startup. So when the program starts, it runs that piece of code once. That code sets up an event that then continues to fire as long as that FB analogue input is updated.
  7. #127
    Jul 2008
    Mechanicsburg, PA
    Quote Originally Posted by 2k1Toaster View Post
    Yup, I changed the file name and namespace/class.
    I attached the trace file. It shows it doing something with the event (I did a search for Logic.cs). FuseGL is version 1.1.0.172 (Alpha Release-2011-06-18 w/update installed). I have firmware 1.3A (from May 21, 2011).
    All the GUI settings I try to put in the config file still don't work. It just crashes.
    Right. Here's what I put:
    Code:
    using System;
    using FB_USB_2011;
    using FuseGL.Logic;
    namespace FuseGL_Logic
        class CarPC
                return null;
            public void doSomethingEvent(FB_Monitor.AnalogueInputPort _port)
                if (_port.Port == 1)
                    if (_port.Value < 1.0)
                        SendKeys.Send("A");
                        SendKeys.Send("B");
                        SendKeys.Send("C");
                        SendKeys.Send("D");
    Here is what I have under Startup Events:
    Code:
      <Startup_Events>
        <events>
          <startup action="FuseGL.ExecuteCode" inputArgs="Logic.cs;FuseGL_Logic.CarPC;doSomethingEvent;{FB.AnalogueInput(0.4)};"/>
          <startup action="FB.ToggleDigitalOutput" inputArgs="Port:0.10" />
        </events>
      </Startup_Events>
    It doesn't do any of the startup events, DO10 doesn't turn on nor logic compiler.
    Also, I think I mentioned this before but it will not allow me to have more then one digital output initialized at the same time.
    I hope it's just something simple on my end.
    Attached Files Attached Files
    Love
  8. #128
    Mar 2006
    Could you also post/attach/email your entire XML config file? That way I can just try the whole thing.
  9. #129
    Jul 2008
    Mechanicsburg, PA
    I posted it a couple posts earlier but here it is:
    Code:
    ?xml version="1.0" encoding="utf-8"?>
      <User_Object type="FuseGL_Object">
        <setting type="string" name="GL - LBL - Show Thing:Raw Analogue Input[0,0]" />
        <image location="internal" path="FuseGL.Configurator.Configurator_IMG_Resources.UserButtonBackground" />
        <text text="Unknown State" />
        <size width="200" height="50" />
        <location x="300" y="50" z="0" alignment="L" />
        <setting type="int" border_size="1" />
        <setting type="bool" mouse_cursor_to_hand_on_hover="false" />
        <events>
          <startup action="FuseGL.ExecuteCode" inputArgs="UpdateLabelText.cs;FuseGL_TextManipulation.InternalFlyCompile_UpdateLabelText;ChangeButtonTextOnAnalogueInputPersistant;{FB.AnalogueInput(0.0)};{this.text};0.000;" outputTo="this.text.text" />
        </events>
      </User_Object>
        <setting type="string" name="GL - LBL - Show Thing:Raw Analogue Input[0,1]" />
        <location x="300" y="100" z="0" alignment="L" />
        <events>
          <startup action="FuseGL.ExecuteCode" inputArgs="UpdateLabelText.cs;FuseGL_TextManipulation.InternalFlyCompile_UpdateLabelText;ChangeButtonTextOnAnalogueInputPersistant;{FB.AnalogueInput(0.1)};{this.text};0.000;" outputTo="this.text.text" />
        </events>
      </User_Object>
        <setting type="string" name="GL - LBL - Show Thing:Raw Analogue Input[0,2]" />
        <location x="300" y="150" z="0" alignment="L" />
        <setting type="bool" mouse_cursor_to_hand_on_hover="true" />
        <events>
          <startup action="FuseGL.ExecuteCode" inputArgs="UpdateLabelText.cs;FuseGL_TextManipulation.InternalFlyCompile_UpdateLabelText;ChangeButtonTextOnAnalogueInputPersistant;{FB.AnalogueInput(0.2)};{this.text};0.000;" outputTo="this.text.text" />
        </events>
      </User_Object>
    nothing out of the ordinary, it's just when I put the <FuseGL_GUI_Settings> tag anywhere in the XML file.
    Love
  10. #130
    Mar 2006
    Try this exe: http://www.fusioncontrolcentre.com/F...ate.2011.08.16
    Rename it to *.zip. Then unarchive it and see what happens. This is the version I am using. I just want to be sure they are similar.
  1. ** NEW Fusion Brain Version 6, Pre-Order NOW **
    By 2k1Toaster in forum Fusion Brain
    Last Post: 04-07-2013, 03:48 PM
  2. Fusion Brain version 4
    By MattFreitag in forum Fusion Brain
    Last Post: 08-01-2010, 05:32 PM
  3. Fusion Brain -- Digital Encoder Beta Test
    Last Post: 09-18-2009, 03:11 PM
  4. Fusion Brain Version 4 Manual
    By greenman100 in forum FB Documentation and Tutorials
    Last Post: 12-19-2008, 03:11 PM
  5. Fusion Brain Version 4 ready for Beta Testers!
    By greenman100 in forum Fusion Brain
    Last Post: 11-13-2008, 11:21 PM
