All the GUI stuff works now. So with my FB connected, using your config file, Output Port 10 should turn on once FuseGL is started, correct?
You have a different version then mine. I was using XXX.172 whereas yours is XXX.202. I'll play around with it and see if things work.
Sorry about all the hassles. I feel like I'm hogging the thread.
Love
Love
Should, but I haven't tried it. I will try around lunch time. I figured getting you on the same version was first priority.![]()
1.9in x 2.9in -- 47mm x 73mm
And logic still doesn't work... just FYI, but that could be related to the startup events
Love
What logic are you referring to?
Try this exe for the startup events: http://www.fusioncontrolcentre.com/F...e.2011.08.16.b
It is also a zip archive, but only the exe inside. Should fix startup events. I don't have a FB available to test right now, but it fired correctly in the code.
Also, FuseGL crashes when coming out of sleep mode.
Love
Does the program crash? If not then FuseGL should be accepting it. Whether or not it is valid, is another story.
I am fairly certain that SendKeys sends to the window with focus. Perhaps try with ASCII letters and have Notepad open in the foreground? Or send F10 and see if the configuration menu pops up.
I have code for sending keys to a window available in the MDX source that should be easily adapted if not copy/pasted with a couple variables changed.
I will try to do this myself once there is time, but for now I believe it can be found here under the "Send A Key or Key Sequence" region in this code file: http://fusioncontrolcentre.com/MDX/S...rMDX/Voting.cs
I am looking into it, thankyou.
Also, I have hired an independent firm to complete some work on FuseGL because I am so busy myself. It's official, Fusion is costing me money lol. But I love it, so no big deal. We will see how this goes, but hopefully it is better for you all.
