Quote:
My process order is this:
PC wakes from sleep, once windows has 'booted', FuseGL will be running (it was running when PC went into sleep), when FuseGL and FB are connected, output X will turn on to tell my audio amplifier to turn on, from there it will be reading various voltages (steering wheel, battery voltages...) and then logic will take out.
Ok, so you need it to be attached to the on-device connect action, not the startup event. There is a way to do this as I use it internally, I will just have to code up an example and make sure all those internal hooks are exposed properly. I get it now.
