Page 26 of 33 FirstFirst ... 161718192021222324252627282930313233 LastLast
Results 251 to 260 of 328
Thread: Fusion Brain Version 6 -- Beta Testing
  1. #251
    Mar 2006
    Colorado, but Canadian!
    Delete your UserConfig.xml
    it has debug code in it. Best to start fresh, or just edit out that line as described above.
    1.9in x 2.9in -- 47mm x 73mm
  2. #252
    May 2006
    That got rid of the info boxes along with all the screen buttons etc.
    I add a sensor and it recognized there was a temperature sensor and offered it as a choice and offered F or C. I selected F.
    The outpur that it generates on the screen is -4.923F.
    Is the sensor bad or do I need to modify the code?
  3. #253
    Mar 2006
    Quote Originally Posted by waltersaegir View Post
    Select Celcius and see what the temperature reports. If it is something between 20 and 26, it is probably working fine assuming it is indoors with humans.
  4. #254
    May 2006
    The output value for Celsius is -20.531C. Which seems good except for the minus sign. Is the minus sign resulting from some reversed connection somehow?
    One quick thing that I noticed about the Fahrenheit calculation code is that it is using the Celsius value in the calculation and "Initialize___TempSensor___Celcius" likely has not been called. Of course I really don't see how "Initialize___TempSensor___Celcius" for the Celsius calculation output (and other functions) get called. Suppose somewhere in your FuseGL engine.
    BTW: getting rid of that initial file and starting with a blank slate/page makes it easier for me to focus on what can be done without the distraction of the demonstration screen buttons/entries that I found confusing as to what they were and what to do with them.
  5. #255
    Mar 2006
    If you look in the userconfig, you will see where the celcius initialization gets called. The sensor along with the rest of the world is a celcius. So the sensor reports back the value in C. If you want it in F, then you have to convert it to F, which is what it does.
    -20C means 0v. You don't have it hooked up to the right port, or you have it hooked up backwards. The red wire is +.
  6. #256
    May 2006
    No difference.
    I *did* have it backwards from the recent fumbling/testing, but upon reversing and restarting several times it has the same output.
    If you remember the pesty debug box that kept popping-up, it read 0.832v and 0 when the sensor was disconnected.
    Fired-up a 6/18 version of FuseGL and the box at the bottom of the screen displayed 0.800 to 0.794 varying just like from the first try months ago, then it did the Auto-Update, restarted and continued to display 0.800 to 0.794
    Yikes! Just added *another* output box and noticed that the *first* index that it asked-for was Fusion Brain Index and *this* time I input "0" and then "001" for the AI index.
    *Now* I see output of 20.347C to 20.513C
    Next I will try a Fahrenheit box. I expect it will now work.
  7. #257
    Mar 2006
    (0.8 - 0.4) / 0.0195 ~= 20.5C or 68F to 70F.
    Sound about right?
  8. #258
    May 2006
    Fahrenheit looks good, but the font on the Button is not scaled.
  9. #259
    May 2006
    Quote Originally Posted by 2k1Toaster View Post
    You will need either the isolator/divider board or build your own resistor divider network for 12v. Using 12v direct will explode your FB.
    I'll order that with the Relay Pack.
  10. #260
    May 2011
    Hi, I have issue with my fusion brain 6
    if I tried to set more than 3 output ON on the same time (or even of there was 2 output ON and tried to set one more output ON) it freeze and I can't set anything ON/OFF unless if I plug out the USB and the power
    but that only if I use power supply and it did not happen when I use USB only
    the power supply output: DC 12v 300mA max && I use FuseGL and hyperterminal and it same .
    how I can solve this ?
  1. ** NEW Fusion Brain Version 6, Pre-Order NOW **
    By 2k1Toaster in forum Fusion Brain
    Last Post: 04-07-2013, 03:48 PM
  2. Fusion Brain version 4
    By MattFreitag in forum Fusion Brain
    Last Post: 08-01-2010, 05:32 PM
  3. Fusion Brain -- Digital Encoder Beta Test
    Last Post: 09-18-2009, 03:11 PM
  4. Fusion Brain Version 4 Manual
    By greenman100 in forum FB Documentation and Tutorials
    Last Post: 12-19-2008, 03:11 PM
  5. Fusion Brain Version 4 ready for Beta Testers!
    By greenman100 in forum Fusion Brain
    Last Post: 11-13-2008, 11:21 PM
