Page 5 of 33 FirstFirst 123456789101112131415 ... LastLast
Results 41 to 50 of 328
Thread: Fusion Brain Version 6 -- Beta Testing
  1. #41
    Feb 2002
    Here is what happens when I make buttons.
    Just grey little weird boxes. Also, when selecting the digital output dialog, sometimes you select a number, click OK, and it disappears. Then you have to do it again.
    I can't click on those boxes, by the way, and they don't control the outputs at all.
    Old School MP3CAR.com member!
  2. #42
    Mar 2006
    Colorado, but Canadian!
    Quote Originally Posted by dscustoms View Post
    Very strange.
    And you are sure you enter the FB index, then DO index, then name? What does your config xml file look like after you exit config mode?
    ---------- Post added at 06:54 PM ---------- Previous post was at 06:50 PM ----------
    Also when this happens, upload your trace file.
    1.9in x 2.9in -- 47mm x 73mm
  3. #43
    Feb 2002
    Whats my FB index?? do index is digital output # ?? How can I reset everything and make a new config? Just download it again?
    Where should I send the trace file?
  4. #44
    Feb 2002
    Ok, here is the trace file. You have to wait a long time to get the info that 0 is the fb index. Its not very clear. The digital outputs don't really match the numbers on the PCB, at all... but now the buttons work. They only show up like the picture above shows, grey boxes, they expand when you click on them.
  5. #45
    Mar 2006
    FB Index is the Fusion Brain Index. When the keyboard pops up, wait a second for the help popup it will explain what the screen is for.
    Either just attach the config file and trace file to a post or email to [email protected]
    To get rid of it manually, just edit the xml file in notepad or whatever else and remove all but the top 3 nodes.
    ---------- Post added at 11:50 PM ---------- Previous post was at 11:32 PM ----------
    Well first, I think we should make sure you have the latest version, so I just uploaded a new copy: http://www.fusioncontrolcentre.com/F...2011-04-18.zip
    Also keep in mind, the digital output buttons right now do an exclusive turn on. So when you turn on X, it turns off all but X and turns X on. The ones that remain on are the ones that are hardcoded on by the firmware right now.
  6. #46
    Feb 2002
    The first button I made with the new software came up ok, the next few all were gray boxes. They do WORK now though Your FB index and DO number popup doesn't have the number 4 on it. Is that some new math?
  7. #47
    Mar 2006
    Interesting. Can you duplicate this, and send that trace file over? Also the xml file it creates after you exit config mode would be nice to see what it is doing.
    No number 4 eh? Yeah that's a... feature. No that is fast typing getting the better of me. All I have to do is add a "4" to the middle of the string of numbers and it should magically appear and work. In the mean time, you should be able to use the keyboard to enter 4... Well maybe not. If it is not on the "approved list" I think it reject it... hmm, I'll make that change shortly.
  8. #48
    Feb 2002
    Ok, there are the two files you asked for.
  9. #49
    Mar 2006
    I love trace files...
    Problem found and fixed (hopefully)
    New application: http://www.fusioncontrolcentre.com/F...2011-04-19.zip
  10. #50
    Feb 2002
    Much better. Now it seems to do what it says. Still no number 4 though, tsk tsk.
    The words scale with the size of the button, all buttons operate (except output 13 which never worked). The dialogs work. When you make a button for output 10, it renames it fly digital output, like the one on the left.
    Any other features hidden in there I can test? ???
  1. ** NEW Fusion Brain Version 6, Pre-Order NOW **
    By 2k1Toaster in forum Fusion Brain
    Last Post: 04-07-2013, 03:48 PM
  2. Fusion Brain version 4
    By MattFreitag in forum Fusion Brain
    Last Post: 08-01-2010, 05:32 PM
  3. Fusion Brain -- Digital Encoder Beta Test
    Last Post: 09-18-2009, 03:11 PM
  4. Fusion Brain Version 4 Manual
    By greenman100 in forum FB Documentation and Tutorials
    Last Post: 12-19-2008, 03:11 PM
  5. Fusion Brain Version 4 ready for Beta Testers!
    By greenman100 in forum Fusion Brain
    Last Post: 11-13-2008, 11:21 PM
