Originally Posted by
dscustoms
Back to Beta!
Testing the new FB v6 I received today I have the following results from hyperterminal.
Most digital outputs work, #17 never turns on, #26 is always on with power or usb, #31 never turns on. The rest are fine, they turn on into a blinking mode with D:xx:1 command.
Analog inputs have no response. a? or A? both reply with 14 channels of 0.0, even when I try the provided temp sensor, or a direct jumper from the +++ to the ain+ channel. No response at all. Jumper causes a little bit of feedback on the board, some leds light up dimly.
Tried my beta unit again, analog inputs work, temp sensor does NOT.
I think there is a short in the wiring though, as I can get large variances in voltage reading by moving the cable near the pin header. Even when it seems to work, I can't get the reading to change with temperature changes...
So, there are my initial responses. What say you? :)
