Page 7 of 33 FirstFirst 1234567891011121314151617 ... LastLast
Results 61 to 70 of 328
Thread: Fusion Brain Version 6 -- Beta Testing
  1. #61
    Mar 2006
    Colorado, but Canadian!
    Quote Originally Posted by dscustoms View Post
    Blinking while connected with a +12 supply. That's twice that you called out my USB bus, so I'll give specs and you can tell me!! (jk!) It's an ASUS M4A89GTD PRO/USB3, and I can plug in every usb device I own without fault.... HMmph.
    I'll try out the new Fuse GL, how do I use the inputs in that program, and what should I do to test the temp sensor? Whats the pinout on that thing?
    The pinout for the temp sensor is the same. The red wire is V+ (3.3v on FBv6, 5v on FBv3/FBv4). The black wire opposite is the actual sensor reading. The middle wire which is bare shielding with heatsink on it (also black but noticeably lighter and not insulated) is ground.
    1.9in x 2.9in -- 47mm x 73mm
  2. #62
    Feb 2002
    Ooh, doesn't seem to work that way at all. I'll rewire and post up.
    Old School MP3CAR.com member!
  3. #63
    Mar 2006
    Updated FuseGL (again, it is 2011-05-20b now).
    This will not flash the digital outputs within FuseGL. Still flashed with Virtual COM, but it is a logic problem. It is not "flashing" it is going at a really really really slow PWM mode. The new firmware updates the PWM speed. Now it will be 'dim' but not flash.
  4. #64
    Mar 2006
    The rest are fine, they turn on into a blinking mode with D:xx:1 command.
    Try with Firmware 1.2d, and the 20-05-2011b FuseGL. Output should be stable constant on.
    Also D:xx:1 command will now make it dim (i.e. 1/255 PWM cycle).
    To turn on, you will have to do D:xx:255. Problem is the firmware doesn't know what "255" is, so I just need to write some code to take the ASCII value and make it an integer value. I will do that tomorrow. I remember I did that in first year uni. What do you know, I will actually have to use something I learned!
  5. #65
    Mar 2006
    Alright, I need to get to bed. I do have a 9-5 as well.
  6. #66
    Feb 2002
    No more blinky! Thanks! I try D:00:10 and D:00:100 and they have the same result. Is that what you meant? D:00:200-255 doesn't work too.
  7. #67
    Mar 2006
    Yes. But they won't work right now, because the COM interface only knows 1 and 0. So you can only turn on a digital output through COM at 1/255 or 0/255. So off or barely on. I need to add some ASCII parsing code to get 1 from '1' and 200 from '2' '0' '0' and so on.
  8. #68
    Mar 2006
    Update 20-05-2011 #3:
    Fixed a bug with legacy systems not liking the Vista/7 system icons used and sometimes preventing the application from starting
    New link available in the first post
  9. #69
    Feb 2002
    I don't know why the other thread was locked, sonicx if you are reading in here. The FB uses the following drivers, you should be able to delete them all and reinstall. \DRIVERS\usbser.sys <- is a windows one, should be fine. \DRIVERS\winusb.sys another windows one i think, then wdfcoinstaller01009.dll, winusbcoinstaller2.dll, wudfupdate_01009.dll. Those numbers may be different if you didn't install the latest drivers.
    2k are there any more?
  10. #70
    Mar 2006
    A thread was locked? One of mine?
    The drivers are actually just the WinUSB drivers from Microsoft, and then the inf file just says, "hey I am one of those". The way I uninstall is plug in the device, look in device manager, right click and uninstall. Select the "uninstall drivers" box. Then unplug and replug. Keep doing this until windows can no longer automatically install drivers for your new device.
  1. ** NEW Fusion Brain Version 6, Pre-Order NOW **
    By 2k1Toaster in forum Fusion Brain
    Last Post: 04-07-2013, 03:48 PM
  2. Fusion Brain version 4
    By MattFreitag in forum Fusion Brain
    Last Post: 08-01-2010, 05:32 PM
  3. Fusion Brain -- Digital Encoder Beta Test
    Last Post: 09-18-2009, 03:11 PM
  4. Fusion Brain Version 4 Manual
    By greenman100 in forum FB Documentation and Tutorials
    Last Post: 12-19-2008, 03:11 PM
  5. Fusion Brain Version 4 ready for Beta Testers!
    By greenman100 in forum Fusion Brain
    Last Post: 11-13-2008, 11:21 PM
