Page 8 of 33 FirstFirst 123456789101112131415161718 ... LastLast
Results 71 to 80 of 328
Thread: Fusion Brain Version 6 -- Beta Testing
  1. #71
    Mo' Programming Mo' Problems
    Sonicxtacy02's Avatar
    Woodbridge, VA
    Blog Entries
    53
    Quote Originally Posted by 2k1Toaster View Post
    A thread was locked? One of mine?
    The drivers are actually just the WinUSB drivers from Microsoft, and then the inf file just says, "hey I am one of those". The way I uninstall is plug in the device, look in device manager, right click and uninstall. Select the "uninstall drivers" box. Then unplug and replug. Keep doing this until windows can no longer automatically install drivers for your new device.
    i might have locked it on accident while moderating late last night but i've since reopened it. It was the firmware thread.
    Live mp3Car Facebook Chat
  2. #72
    Feb 2002
    I thought it wasn't showing up in device manager? If it is, then its easy.
    Old School MP3CAR.com member!
  3. #73
    Woodbridge, VA
    Blog Entries
    53
    Well i tried to uninstall/reinstall drivers, removing all hidden com ports from the system, replacing usbser.sys and i still cannot connect to my v6 via VCP. Its like there's something physically blocking the com port which obviously isnt possible. I'm gonna have to find a way to put vis studio 2008 on another one of my systems to do any work on my plugin. Having to update to .net 4.0 is a last resort because its not a popular option for Riderunner/Centrafuse people.
  4. #74
    Low Bitrate UniqelyCommon's Avatar
    Nov 2008
    Teh Internets
    Post
    For anyone interested, the Fusion Brain v6 used in Ubuntu (I'm v10.10) (Linux) doesn't need any configuration. Plug it in and the virtual serial port is recognized, not as /dev/tty0 or others, but as /dev/ttyACM0 or similar. This is an almost generic, but specialized serial port connection.
    To issue commands, open a terminal and type (assuming ttyACM0):
    Code:
    echo *IDN? > /dev/ttyACM0
    You should see the information display
    To turn port 0 on:
    Code:
    echo D:00:255 > /dev/ttyACM0
    or get the analog signals:
    in one console:
    Code:
    cat /dev/ttyACM0
    and in another:
    Code:
    echo aa? > /dev/ttyACM0
    (yes, a? A? aa? and AA? are all different commands, try them out
    connection speeds vary each time the device is plugged in. That said, unless you're changing all 30 ports every tenth of a second the slower speed is still pretty quick.
    I wrote a few sample scripts to control the outputs, but you'll have to make them executable
    Code:
    chmod a+x light*.txt
    Attached Files Attached Files
    Last edited by UniqelyCommon; 06-10-2011 at 02:26 PM. Reason: added linux term for searching, changed 'echo' to 'cat' (oops)
  5. #75
    Mar 2006
    Colorado, but Canadian!
    ^^ Great!
    And yes a? A? and aa? are all different. The connection speed shouldn't really matter as I don't strictly honour it within the FB. I try to get the host's attention all the time irregardless of what speed you set. In Windows this results in the speed connection not mattering. Setting it to 2400bps 9600bps, or 115kbps all work exactly the same and at the same speed. If you set it more than 115kbps the FBv6 tries to error and say "hey I can't go that fast over UART" and signal an error. Some programs like Hyperterminal do nothing and it works, others that actually support that standard barf and give the error.
    So in Linux, the speed shouldn't vary at all below 115kbps.
    1.9in x 2.9in -- 47mm x 73mm
  6. #76
    Nov 2008
    Teh Internets
    Interesting Might just be the console executing the scripts, other things running, etc. :P
    I'm a bash scripting n00b so I don't have any neat script that'll display analog values as they're updated.
    I'm hoping this makes it easy to connect to my x86 Android development box, I'll update later if there's any interest.
    With the new Android-Arduino connection hardware coming out from google, it would be pretty cool if the next FBrain version had Tx/Rx pins. Hook your phone/tablet up to the car, use a Fusion Brain App. Prob. a lot of work though, and don't know if there's enough community that'd use it
  7. #77
    Mar 2006
    Quote Originally Posted by UniqelyCommon View Post
    The next version wont have TX/RX lines but it will have a way of connecting to more portable devices without the need for a copper link.
  8. #78
    Nov 2008
    Teh Internets
    The magic keeps coming!
  9. #79
    Mar 2006
    Update available 18-06-2011
  10. #80
    Feb 2002
    Whats it do now?
  1. ** NEW Fusion Brain Version 6, Pre-Order NOW **
    By 2k1Toaster in forum Fusion Brain
    Last Post: 04-07-2013, 02:48 PM
  2. Fusion Brain version 4
    By MattFreitag in forum Fusion Brain
    Last Post: 08-01-2010, 04:32 PM
  3. Fusion Brain -- Digital Encoder Beta Test
    Last Post: 09-18-2009, 02:11 PM
  4. Fusion Brain Version 4 Manual
    By greenman100 in forum FB Documentation and Tutorials
    Last Post: 12-19-2008, 02:11 PM
  5. Fusion Brain Version 4 ready for Beta Testers!
    By greenman100 in forum Fusion Brain
    Last Post: 11-13-2008, 10:21 PM
