Page 9 of 33 FirstFirst 12345678910111213141516171819 ... LastLast
Results 81 to 90 of 327
Thread: Fusion Brain Version 6 -- Beta Testing
  1. #81
    Mar 2006
    Colorado, but Canadian!
    It should work on any system now with OpenGL including those that don't support non-power-of-two textures. Also it has a built in updater now. Working on variable support now.
    1.9in x 2.9in -- 47mm x 73mm
  2. #82
    Mar 2006
    One of the big things that was requested often was what I am now calling "persistent variables". Variables that retain their previous value when the program is launched. That is all working now. Now working on getting them to be visible to the logic routines.
  3. #83
    Feb 2002
    Redding, California, United States
    Well, I can't use the new fuse GL at all. It updates, then crashes when I try to add a button. I've got this great RGB led array that I want to control and I can't do anything
    Old School MP3CAR.com member!
  4. #84
    Mar 2006
    Quote Originally Posted by dscustoms View Post
    Can you post your log? I can't tell what is happening without it.
  5. #85
    Feb 2002
    Which log?
  6. #86
    Mar 2006
    the text file that is generated everytime you run the program in the same directory as the exe
  7. #87
    Feb 2002
    I'm not getting log files. There was an updater log with nothing useful in it.
  8. #88
    Mar 2006
    Everytime the program is opened a file called "FuseGL_Trace.txt" is created
    looks like:
    Code:
    Fusion Control Centre -- FuseGL {1.1.0.161}
    	Trace Output File
    stuff here...
  9. #89
    Jun 2004
    Quote Originally Posted by 2k1Toaster View Post
    looks like:
    Code:
    	Trace Output File
    stuff here...
    Mine doesn't get created if the program crashes..... it usually doesn't show up until after I close the program, not on program open.
  10. #90
    Jun 2004
    BTW - right clicking while in edit mode crashes the program. Sometimes using the onscreen keyboard does/sometimes not.
    I've seen some odd multiple brain handling that I'm not sure what's going on yet - need more testing but here's what I saw so far.
    Recognizes 2 brains (txt file has 2 instances) but I can't figure out how to program for both (separate issue, I'm sure). If I've had both connected, I have to delete the .txt file for instances before it will recognize 1 by itself. I tried both brains on the same cable/port & neither would connect with the sample program. delete the txt file & either worked.
  1. ** NEW Fusion Brain Version 6, Pre-Order NOW **
    By 2k1Toaster in forum Fusion Brain
    Last Post: 04-07-2013, 02:48 PM
  2. Fusion Brain version 4
    By MattFreitag in forum Fusion Brain
    Last Post: 08-01-2010, 04:32 PM
  3. Fusion Brain -- Digital Encoder Beta Test
    Last Post: 09-18-2009, 02:11 PM
  4. Fusion Brain Version 4 Manual
    By greenman100 in forum FB Documentation and Tutorials
    Last Post: 12-19-2008, 02:11 PM
  5. Fusion Brain Version 4 ready for Beta Testers!
    By greenman100 in forum Fusion Brain
    Last Post: 11-13-2008, 10:21 PM
