Well now that it's talking, I guess I'm beta testing!
Why are my analog values reading
a?
0.741v
0.645v
0.0v
0.0v
0.0v
0.0v
0.870v
0.806v
0.806v
0.2064v
0.1838v
0.870v
0.903v
0.903v
With nothing connected?
Drivers: http://www.fusioncontrolcentre.com/FBV6/FBv6%20INF.zip
Software (as of 23/01/2012): HERE -- http://www.fusioncontrolcentre.com/FuseGL/FuseGL.zip
Update 24-01-2012:
Added the ability to "redraw" User Objects (change size + location) via the Configurator instead of just moving around attached to current size
Added the ability to delete User Objects via the Configurator
Update 23-01-2012 through 25-10-2011:
Added all currently produced sensors to internal configuration
Improved stability
Improved Auto-Updater (to better show it is updating and not to be in use)
Improved Menu Controls in Configuration Mode
Made Text Help areas appear immediately when a screen appears instead of only when mouse is hovered
Added a MAX_VALUE to the user accessible analogue input port data
Update 01-10-2011:
Added an internal function to send keystrokes to another program, still in testing phase
Update 29-09-2011:
Allowed external fly-compile code to use references not included in FuseGL itself but included with .NET
Update 18-06-2011:
Added automatic updating
Update 20-05-2011 #3:
Fixed a bug with legacy systems not liking the Vista/7 system icons used and sometimes preventing the application from starting
Update 20-05-2011 #2:
Fixed a bug with flashing Digital outputs on the newest firmware. Requires Firmware 1.2d
Update 20-05-2011:
Updated the way analogue inputs work internally. Now it is the same between the COM object and WinUSB interface. Requires the 20-05-2011 firmware flash: http://www.mp3car.com/fusion-brain/1...05-2011-a.html
Update 19-05-2011:
Lots of stuff...
Update 19-04-2011 #2:
Fixed y-inversion for moving User Objects in the internal configuration
Update 19-04-2011:
Fixed a GUI Rendering Problem with multiple runtime generated User FGLObjects
Update 18-04-2011:
Some extras
Update 17-04-2011:
Added some error checking and fixed a height reversal bug
Update 16-04-2011:
This one finally made public the most important part of FuseGL.
I will let you experiment for yourself. It is rough and limited in its current implementation, but workable.
Press F10 after the application opens to open up a world of awesomeness...
1.9in x 2.9in -- 47mm x 73mm
a?
0.741v
0.645v
0.0v
0.0v
0.0v
0.0v
0.870v
0.806v
0.806v
0.2064v
0.1838v
0.870v
0.903v
0.903v
Old School MP3CAR.com member!
Because they are floating and you don't have final hardware. I ran out of components to mitigate this. I only had like 5 pieces, so I soldered them all onto my board.![]()
Just like V4, it wont effect anything when you connect a sensor. And if nothing is connected, then why bother?
I took a 50/50 chance of circuit A working or not. It didn't, so circuit B will be used and will make everything read 0 even when floating. Don't worry, you'll get new boards when the beta is over.![]()
I can't see anymore...
The green LEDs are too bright, and the board is getting hot as hell from having them all on.
I'm actually wearing my laser safety glasses to work on it right now
Ok, All LEDs are working according to the status of the output, including the broken ones. (They match the state)
Output 16 is flashing, can't turn it on or off.
Output 17 is ON, can't turn it off.
Output 26 is ON, can't turn it off.
Output 13 will not turn on.
Output 31 will not turn on.
Each time I turn an output on, it's adding another 20 mA to the total current draw. (For the LED only, I assume) Board really gets too hot to touch by the time I turn all the outputs on, took a few minutes and it crashed (is there thermal protection on this thing?). I did a power cycle and it came back to life.
---------- Post added at 09:55 PM ---------- Previous post was at 09:42 PM ----------
That last test was with +12 connected to the power supply port. When do I actually need to connect to that port? What are the capabilities with +12 vs USB power?
Yes the manufacturer used the wrong LEDs (regular non high efficiency ones) and the wrong resistors. So at 12v these suckers will get hot.
Yes there is current limit protection from the PC, not thermal protection from the input. It will never get that hot once the correct LEDs are used.
Right now, outputs 16-23 are going to preset PWMs for testing. I can change that at anytime. The top right LED is a heartbeat right now. If the board dies, so will that LED.
Are you powering it from 12v? Right now, I would try to limit turning on all those LEDs from 12v. The input voltage can be anything from about 4.5v to 28v. The LED resistors I believe are 600ohms which is too low.
---------- Post added at 11:01 PM ---------- Previous post was at 10:56 PM ----------
Everything except the actual output pin power is operational off of 5v USB. USB is current limited to 500mA for everything. But much less power through the LEDs then.
Yeah, they measure at 600 or so. That heartbeat LED is using port 16, so just forget about that one? What about the other ports I'm having issues with, just glitches?
---------- Post added at 10:03 PM ---------- Previous post was at 10:01 PM ----------
Ok, I'll find a 5 - 6 volt power supply to do some testing with.
When you are just doing COM, USB power only is sufficient.
And for betas:
0: 0,2
1: -
2: 0,2
3: 3,5
4: 4
5: 3,5
6: 6
7: 7
8: 8
9: 9
10: 10
11: 11
12: 12
13: 13
14: -
15: 15
16: 16
17: N/A
18: 18
19: 19
20: 20
21: 21
22: 22
23: 23
24:
25:
26:
27: 27
28: 28
29: 29
30: 30
31: -
24 individual outputs
4 paired outputs (function as 2)
3 dead
I'm not experiencing the paired outputs, and only the pins I listed above have issues (16,17,26,13,31) All the other ones address properly, matching their screen printed number, and pulling system voltage when addressed.
The far top right column will not be fully functional with this firmware. Then the two bottom left on the horizontal row might not be depending on USB state. As for 31, I think that is just dead.
The dead ones cannot be fixed. All the others that work but you can't control, I can change to be controllable with a firmware update. This version is upgradable over USB.
To test to make sure the bootloader works, short the reset header while the board is powered. As long as the board doesn't loose power it is then in bootloader mode. To exit this mode, unplug the power completely and wait a couple seconds. Then plug it back in.
Is the reset header the two pin header? What is the 6 pin header for?
Yep, it is. And the bootloader works and loads as a USB bootloader HID.
