Page 2 of 7 FirstFirst 1234567 LastLast
Results 11 to 20 of 63
Thread: Multiple Button w/ Resistors
  1. #11
    Mar 2006
    Colorado, but Canadian!
    You need a pulldown to ground. You are basically floating an input which is an electrical no-no. So take a couple hundred Kohm resistor and tie it between the analogue input and ground.
    1.9in x 2.9in -- 47mm x 73mm
  2. #12
    Aug 2005
    Quote Originally Posted by 2k1Toaster View Post
    Thanks for chiming in. You mean literally from the ground pin to the input pin?
    I'm googling what you said so I can understand it, but just wanted to confirm that's what you meant.
  3. #13
    Mar 2006
    Quote Originally Posted by SKiTLz View Post
    Indeed I do.
    Basically the FB's input is an empty bucket when you power it on. Then you press your button and it fills the bucket up to the level specified by your resistor divider combo. The FB reads the level of this bucket by skimming a bit off the top. (A very very very small amount, like a couple drops). When you disconnect your button that bucket is still full. What you need to do is poke a hole in the bucket. So when the button dumps in its goo, it can drain away when disconnected. Now if you make this hole too small, it won't drain. If you make this hole too big, the button has to put more current (more pressure) to maintain the same level.
    So pulldowns are a common occurance.
    Alternatively, you can connect the input to power and ground the button through a resistor.
  4. #14
    Aug 2005
    Well, I think I killed my brain. I can't get MDX to read any voltage now. Make you a deal. I'll buy another one if you can give me a diagram so I don't kill the next one..
  5. #15
    Mar 2006
    How EXACTLY did you hook it up and what values of what did you use.
    Also, there is a thermal fuse on there. If the board looks dead, give it a few minutes to cool down and try again. You may have killed that output, but the brain should come back to life.
    ---------- Post added at 11:34 PM ---------- Previous post was at 11:33 PM ----------
    And please tell me you were messing around with bare leaded components with a live device...
  6. #16
    Aug 2005
    Ok the board appears to have come back to life. Looks like you called it..
    This is what I had/have.
    Left side of Button -> 100ohm resistor -> +5V
    Right side of Button -> Input
    +5V -> 100k ohm resistor -> input
    I see it lowers the voltage when the button isn't pressed, but pushing the button still does nothing.
    I know i'm in over my head, but I will get it... Eventually.
  7. #17
    Mar 2006
    Are you sure you meant +5v on both of those?
    When it goes dead like that, you shorted it. VERY bad. But protected against slightly.
  8. #18
    Aug 2005
    Sorry.. I made a mistake. This is what I meant.
    +5V -> 100k ohm resistor -> Ground
    That is how I interupted your bucket analogy. But that doesn't mean I got it right.
  9. #19
    Feb 2002
    You were supposed to hook the ground through the 100k ohm resistor to the input.
    ---------- Post added at 11:09 PM ---------- Previous post was at 11:06 PM ----------
    The input has three pins. V+, input, Ground. Connect V+ to one side of your button, from the other side of your button connect your 100ohm resistor in series to your input pin. Then connect the input pin to the ground pin with a 100K ohm resistor (since its what you have).
    right?
    Old School MP3CAR.com member!
  10. #20
    Mar 2006
    Code:
    +5v
    <    1Kohm to 250Kohm
     |--- Input
    BUTTON
    GND
  1. multiple command button syntax help
    By yonu in forum RR Skins
    Last Post: 01-13-2010, 11:32 PM
  2. setting multiple keyboard strokes in one button
    By igo4bmx in forum Road Runner
    Last Post: 09-02-2009, 06:28 PM
  3. MDX -- Linking multiple Outputs/Votes to a single Display Button
    By 2k1Toaster in forum FB Documentation and Tutorials
    Last Post: 04-06-2008, 05:54 PM
  4. FS: 75 Ohm Resistors (4 Available)
    By AEFL92 in forum Classified Archive
    Last Post: 02-08-2005, 09:12 PM
  5. Using resistors
    By babas151 in forum General Hardware Discussion
    Last Post: 03-27-2002, 02:57 PM
