Page 4 of 7 FirstFirst 1234567 LastLast
Results 31 to 40 of 63
Thread: Multiple Button w/ Resistors
  1. #31
    FLAC -zip-'s Avatar
    Ontario/Canada
    Skitlz what size resistor did you use in the end? Sorry to hear about your board, but you are getting there!
    Sound Stage
    Eclipse|MTX|Infinity
  2. #32
    Mar 2006
    Colorado, but Canadian!
    Ok, your button is on Analogue Input #10.
    The cascading effect is normal and a GOOD sign. There is really one 1 analogue input on the FB, and then it switches really really fast between all the inputs and reads them. This is common practice. THe problem is when the pin is floating again, you have nowhere for that excess charge on the sample/hold cap to go. So it just sits there and slowly degrades. Until it samples Analogue #10 again and it recharges it all the back up. If you put a jumper to ground on Analogue Input #1, that should make it easier for you to visualize.
    I'm now back to reading 0 when the button is pushed... Bahhh..
    Perfect! Then it is working. The way I described was it is high when not pressed, low when pressed. This seems to be what you are getting.
    Huzzah, a single button works.
    Now you can read up on voltage dividers (wikipedia has a good article).
    Now make:
    Size R1 and R2a-R2d so that they make different voltages when connected.
    1.9in x 2.9in -- 47mm x 73mm
  3. #33
    Aug 2005
    Alright here is where I'm at. Haven't had a chance till today.
    I'm using the "active high" solution. Based on your math that I stole, on button 1 pus I would be seeing 4.9950 and button2 push 4.7755
    Both button's I'm seeing 4.9902. Which is very close to button 1, but for some reason I don't seen to be getting a different value for button2. Soo close.
    That 4.6 is supposed to read 4.7. Typo.
  4. #34
    FLAC Mickz's Avatar
    Sep 2009
    Australia
    Quote Originally Posted by SKiTLz View Post
    That result is correct for the values you are using.
    There will be roughly 200mv (0.2) volts difference with those values in that circuit
    It may be that you are loading the input to the ADC and causing an error.
    Try a 10k instead of 100k and see what the reading is.
    Surface Pro 2 128GB portrait mode, Win8.1, Reverse camera, Dual 10HZ GPS RX's for Speed Display & Sat Nav, FM-DAB & Phone Modules, iDrive interface. T-Screen HVAC control, custom microcontrollers, microcode and FE. Previous Car-PC Project
  5. #35
    Aug 2005
    Quote Originally Posted by Mickz View Post
    Hmm.. Is my math wrong?
    I was doing 5v * (100000/(resistor size + 100000)) = End Voltage
    I stole that from one of 2k1Toasters posts.
    I'm not sure if you misread my post. The values are what I THOUGHT I would see, but I'm seeing the exact same value for both buttons, 4.9902V
  6. #36
    FLAC Mickz's Avatar
    Sep 2009
    Australia
    I didnít word that post correctly. The expected voltages are correct IE 200mv difference.
    Your result may skewed by connections, layout or loading.
    See what you get with a 10k instead of 100k. This should give you a better idea of whatís going on.
  7. #37
    Aug 2005
    I didn’t word that post correctly. The expected voltages are correct IE 200mv difference.
    See what you get with a 10k instead of 100k. This should give you a better idea of what’s going on.
    Ok so I dropped the 100k down to a 10k. It lowered the voltage on both buttons when pushed from 4.9902 to 4.7898. The problem is both buttons are still acting the exact same, despite having different size resistors on each button's INPUT connection.
  8. #38
    FLAC Mickz's Avatar
    Sep 2009
    Australia
    Do you have a multimeter to read the voltages at the ADC input pin of the Microprocessor.
    You need to find where the error is. By your description it sounds like it’s NOT the micro.
    You should read roughly 4.94 and 3.39 volts with a 10k.
  9. #39
    Aug 2005
    I do.. So you just want me to check the voltage on the input pin manually instead of trusting the FB reading?
    If thart is what you meant, I get the same reading on my multimeter. Well very close, it's not the best meter so probably a little inaccurate.
    Button not pressed. 3.18
    Button pressed. 4.79
    I just can't work out why both buttons are identical despite having different size resistors.
    ---------- Post added at 05:44 PM ---------- Previous post was at 05:25 PM ----------
    I checked the voltage at the button.
    1.67V not pushed.
    0V pushed.
    That makes no sense too me.
  10. #40
    FLAC Mickz's Avatar
    Sep 2009
    Australia
    You are measuring across the 10k resistor?
    The Micro reads between ground and the input pin.
    Disconnect it from the FB and read across the 10k resistor.
    ---------- Post added at 10:22 AM ---------- Previous post was at 10:09 AM ----------
    This is a simple circuit.
    Without a connection to the FB AND with a regulated 5v supply:
    Both switched open. 0 volts across the 10k.
    Switch 1 pressed (100 ohm) roughly 4.79v across the 10k.
    Switch 2 pressed (4k7) roughly 3.18v across the 10k.
    When you connect to the FB and measure across the 10k – If you read a voltage with both switches off then the FB has a pull-up resistor on that ADC input or you are using the wrong input or there is some other wiring issue with that input.
  1. multiple command button syntax help
    By yonu in forum RR Skins
    Last Post: 01-13-2010, 10:32 PM
  2. setting multiple keyboard strokes in one button
    By igo4bmx in forum Road Runner
    Last Post: 09-02-2009, 05:28 PM
  3. MDX -- Linking multiple Outputs/Votes to a single Display Button
    By 2k1Toaster in forum FB Documentation and Tutorials
    Last Post: 04-06-2008, 04:54 PM
  4. FS: 75 Ohm Resistors (4 Available)
    By AEFL92 in forum Classified Archive
    Last Post: 02-08-2005, 08:12 PM
  5. Using resistors
    By babas151 in forum General Hardware Discussion
    Last Post: 03-27-2002, 01:57 PM
