Page 5 of 7 FirstFirst 1234567 LastLast
Results 41 to 50 of 63
Thread: Multiple Button w/ Resistors
  1. #41
    Aug 2005
    I'm affraid I'm not really following. All I know is both "active high" or "active low" both seem to work for me, except both buttons are dropping/upping the voltage to the same value.
  2. #42
    FLAC Mickz's Avatar
    Sep 2009
    Australia
    Quote Originally Posted by SKiTLz View Post
    Measure the voltage across the 10k resistor what is hard about that?
    The top of the 10k should go to the input connection the FB, the bottom of the 10k should go to a ground connection on the FB.
    Active high and active and low are meaningless without reference.
    Active High means that when an event occurs the output will be high IE +5v.
    Active Low means that when an event occurs the output will be low IE 0v.
    It usually applies to Digital outputs / inputs.
    The signal you are reading is an analogue signal – it can have any value (between 0 and 5v in this case) not just high or low, 5v or 0v.
    The ADC (analogue to digital convertor) of a Micro does not care about anything except the voltage at its input with reference to ground. That voltage is the voltage developed across the 10k resistor.
    Unless the FB ADC inputs have been modified from the norm, it should be the same.
    Surface Pro 2 128GB portrait mode, Win8.1, Reverse camera, Dual 10HZ GPS RX's for Speed Display & Sat Nav, FM-DAB & Phone Modules, iDrive interface. T-Screen HVAC control, custom microcontrollers, microcode and FE. Previous Car-PC Project
  3. #43
    Aug 2005
    I appreciate the help. I just don't exactly understand the theory behind everything so bare with me.
    Ok so I measured across the 10k resistor (INPUT->GND) and it is 3.19V unpressed and 4.78V pressed. So exactly what I said, I was measuring it correctly. But again, it is 4.78V pressed for BOTH buttons.
  4. #44
    FLAC Mickz's Avatar
    Sep 2009
    Australia
    That 4.6 is supposed to read 4.7. Typo.
    No problems – I understand, we have all been there and started there. However trying to fault find when you can’t see or touch the equipment is not easy so excuse the repetitive questions.
    If you look at your circuit there are two buttons. With both buttons off (un-pressed) AND no connection to the FB there HAS to be 0 volts across the 100k (now a 10k for our test)
    Once that has been established, connect it to the FB, there should be 0 volts across the 10k under the same condition (no button pressed), is this the case?
    You said “But again, it is 4.78V pressed for BOTH buttons.”
    If this is the case without it connected to the FB then you either have:
    A: The circuit is wired up differently then shown.
    B: The +5 volt supply is dropping when you press a button.
    C: The resistor values are not what they indicate.
    D: You have a faulty lead or connection.
    E: You have discovered a new unheard of electrical principle
  5. #45
    Raw Wave
    Nov 2009
    Not that I understand why the 100R resistor is there (I haven't read the thread thru) but take it out - you aren't measuring a 0.1% voltage change.
    Else make it substantial - 10k or more.
    (I've forgotten the analog impedance of the FB....)
  6. #46
    FLAC Mickz's Avatar
    Sep 2009
    Australia
    You are correct of course, however for the purpose of identifying the current problem, I was trying not to confuse the situation by changing to many things at once.
    I believe the FB is switching a number of inputs to one ADC port. One of the problems with a low resistance into the ADC port is the accuracy loss caused by the inability of the ADC conversion CAP to fully charge during the allocated sampling period. From memory around 1.5 to 3k is the recommended minimum load resistance for the Microchip ADC ports running at low speeds.
    At the moment we are trying to get a correct voltage reading without any connection to the FB Micro.
  7. #47
    Mar 2006
    Colorado, but Canadian!
    The input impedance should be kept below 2.5Kohms for the ports. It is a single ADC, but the time it samples for is extremely long. I think a picture of the setup is in order. It definately sounds like something is very wrong with the wiring.
    1.9in x 2.9in -- 47mm x 73mm
  8. #48
    Aug 2005
    Finally had some more time to play...
    Mickz I took your advice.. I have everything connected exactly as show. If I measure the voltage across the 10k (probe on either side) I'm getting 3.2V, and you are saying I should be getting nothing. So what gives. Is it possible my buttons are passing the voltage and work on some kind of resistance instead?
    I know you guys probably think I've got something hooked up wrong but it's honestly exactly as I diagramed.
    Also If I measure voltage across the button (while connected to the FB) I get 1.18V. So clearly voltage is passing. Why it is lower at the button that I see at the brain is beyond me though.
    ---------- Post added at 11:05 PM ---------- Previous post was at 10:40 PM ----------
    I can put the findings up.. Hopefully you guys can interupt them as to what it means..
    I just put my multimeter inline on the 5V line. So intead of +5V PIN -> Switches it is +5V Pin -> MM lead -> MM lead -> buttons..
    Now the FB is reading 0V like your saying it shoud.. Well very close.. It's getting a 0.0.... reading still.
    What the hell. Having my multimeter inline on DCV 20 shouldn't change anything to my knowledge.
  9. #49
    FLAC Mickz's Avatar
    Sep 2009
    Australia
    Having the multimeter in line is the same as putting a large resistor in line. The voltage will drop.
    It’s lower with the FB connected because of the impedance of the FB.
    You need to disconnect each switch from the circuit. One of them is leaking or they are not simple on/off switches.
    They don’t have an inbuilt LED by any chance?
  10. #50
    Aug 2005
    Since I have everything connected EXACTLY as you guys are saying, same resistor values etc etc, the only variable is the actual buttons themselves. I've attached some pics as close up as I could get (need a macro lense). Maybe something jumps out at you cause I'm seriously lost why this still isn't working. The more reading I do the more I'm convinced everything is correct.
  1. multiple command button syntax help
    By yonu in forum RR Skins
    Last Post: 01-13-2010, 10:32 PM
  2. setting multiple keyboard strokes in one button
    By igo4bmx in forum Road Runner
    Last Post: 09-02-2009, 05:28 PM
  3. MDX -- Linking multiple Outputs/Votes to a single Display Button
    By 2k1Toaster in forum FB Documentation and Tutorials
    Last Post: 04-06-2008, 04:54 PM
  4. FS: 75 Ohm Resistors (4 Available)
    By AEFL92 in forum Classified Archive
    Last Post: 02-08-2005, 08:12 PM
  5. Using resistors
    By babas151 in forum General Hardware Discussion
    Last Post: 03-27-2002, 01:57 PM
