Results 11 to 20 of 23
Thread: Control Your Car Over the Internet
  1. #11
    Feb 2002
    Which Sheeva plug should I get, multiple manufacturers and choices. Are there any minimum limits to what you are proposing here? Is yours a wifi model, and do they handle wifi well?
    For always on, mounted in the car, it's going to need a good stable connection. Should I just get the most basic plug computer and add a USB wifi card?
    I'm a little concerned about the power draw of a persistent wifi connection, need to keep it low.
    Old School MP3CAR.com member!
  2. #12
    Jan 2008
    Dartmouth, MA
    As a little update on the status of the coding: I had to make an unexpected trip home from college this weekend, so I'm going to be a weekend behind on this project. The aim now is to get a mostly perfect version 1.0 sometime next weekend.
    Quote Originally Posted by dscustoms View Post
    The minimum limits are likely almost anything that can physically run python. On my linux box, I haven't seen the program surpass 12 MB of ram and 5% CPU. The 5% cpu only happened when it was searching for devices or getting absolutely spammed with HTTP requests (50 requests/second). The normal CPU usage when it isn't doing anything except waiting for an HTTP request is 0%. I'm sure that once I add a rules engine, there will be a bit more constant CPU usage, but it should really just result in similar, quick spikes of only a few percent. Overall, I've designed this for efficiency in terms of both CPU use and ram accumulation since it is designed to run long term without being touched on low-power platforms. Eventually I would like to get it to run on something as low power as DD-WRT router.
    Is yours a wifi model, and do they handle wifi well? For always on, mounted in the car, it's going to need a good stable connection.
    Mine is not a wifi model, but I wish it was. I'm sure they wouldn't put a junk wifi chip in it though. I have the most basic, original sheeva plug as I was an early adopter, and I am definitely envious of the newer plugs. On a side note, to satisfy that envy, I'm now toying with the idea of a complete arm-based always-on linux car PC based on the http://www.pandaboard.org/ that will replace my current x86 pc, sheeva plug, and wireless router in one fell swoop. The existence of openMobile makes that look more possible than before.
    For power, check out: http://www.lesswatts.org/tips/wireless.php
    Anyway, to be make your decision a little more cloudy, here's some pros and cons I can think of right now:
    -The wifi sheeva plug also adds more features. Whether you need them or not is up to you.
    -USB wifi cards may consume more or less power depending on the card
    -Many USB cards offer poor performance (although this doesn't require much)
    -I'm not sure if the wifi sheevaplug has an onboard IPEX connector for an antenna, as an antenna will likely make a big difference.
    My Nearly Complete Car:
    http://www.mp3car.com/vbulletin/show...ed-car-pc.html
    Micro Control Center... Control Your Car Across the Internet
    http://www.mp3car.com/fusion-brain/1...-internet.html
    Website: (It's a work in progress, really. All my projects have taken me from ever really developing it.)
    http://paulfurtado.com/
  3. #13
    licensed to kill - FKA kev000
    tripzero's Avatar
    Aug 2006
    16.40618, 120.61106
    I just wanna say, welcome back PaulF. It's been a while .
    Also, the pandaboard could be quite awesome. It's on my list of things to try out.
    Finally, osdash has a generic "remote control" service that seems to try to accomplish the same goal. maybe there is a way to combine resources here.
    Former author of LinuxICE, nghost, nobdy.
    Current author of Automotive Message Broker (AMB).
    Works on Tizen IVI. Does not represent anyone or anything but himself.
  4. #14
    Jan 2008
    Dartmouth, MA
    Quote Originally Posted by tripzero View Post
    Thanks, feels good to be back!
    Definitely is awesome. I finally got in the mail this week. Performance is awesome so long as you put the OS on a USB hard drive rather than SD card. At least this is the case for Ubuntu. We need to have a conversation about which OS/software path I should go down for getting a decent carpc setup out of this. Let's not hijack this thread though.
    I didn't realize all the OpenICE stuff was still under development...
    Anyway, from how I see osdash, the individual project goals are slightly different, but our overall CarPC goals are similar. Ex. my project goal is very focused on getting microcontrollers controlled with roughly no work from the end user. OSdash, has a higher level goal of getting everything in your car under control and require more setup. Making a daemon for every microcontroller, for every platform would be a pain. So how do we bring these two together...
    My project right now is structured as...
    --Devices (plugins)
    A simple python class that provides 3 dumb-simple methods for a device and one additional function for finding devices.
    --Abstraction for devices
    Wraps device classes with all the nice functions that a control program would require
    --Manager
    Maintains connections with all the devices, naming for devices, processing for commands, and routing commands to devices.
    --Commanders (plugins)
    Control the devices through the manager. Each commander has a set priority so that if you, say, send a command through the web interface to turn on an output, but the rules engine wants the
    output to be off, the web command wins.
    But with this setup in place, I can easily write a "commander" for the DBUS or OSdash or both. This way we complete each other's overall goals...
    Sound good? or what are your thoughts?
  5. #15
    Jan 2008
    Dartmouth, MA
    Update on this... I got a lot busier during finals than I though I would but now I'm out of school and have much more free time. In roughly 1 and a half weeks this should pretty much be done and reliable. Also, should have FBv6 support by then too. Sorry about the wait!
  6. #16
    Feb 2002
    Excellent!
  7. #17
    Jan 2008
    Dartmouth, MA
    Sorry guys, I've been battling windows and life. I've started an internship at VMware which eats a very large chunk of time. Windows is also killing me. I can't get a stable USB connection from python on windows.
    I'm going to release the linux version of this in the very near future since it is completely stable. I'll offer stable windows support in a few weeks via IronPython or Jython.
  8. #18
    Feb 2002
    Is it going to be Fusion Brain V6 compatible?
  9. #19
    Low Bitrate sk8rjess's Avatar
    Nov 2007
    congrats on the internship man. vmware is prob the most famous and most used cross-operating system software.
    they call me hack
    Independence Auto Tech
    http://ctxdesigns.com - web design :)
    "Let us search out and examine out ways, and turn back to the Lord; Let us lift our hearts and hands to God in heaven." - lamentations 3:40-41
  10. #20
    Jan 2008
    Dartmouth, MA
    You bet. My first paycheck just cleared today, so I ordered the FBv6 at lunch. I'm rebuilding my carpc around the fbv6 so I'm going to get that support in asap. Sorry it's taking me so long to follow through with this program. So many things keep taking me away from my hobbies. I'll update you in a couple of days. I really want to say everything will be final and fbv6 support will be in this weekend, but I'm really unreliable about these deadlines.
    Quote Originally Posted by sk8rjess View Post
    Thanks man. VMware is awesome. I didn't realize just how big they were until my orientation. They exploded from 625 million in '05 to 35 billion in '11. Virtualization is completely taking over data centers and no other company can touch them in that regard.
  1. Japanese Internet vs. North American Internet
    By readytoget in forum Off Topic
    Last Post: 02-22-2009, 10:28 PM
  2. Replies: 2
    Last Post: 06-28-2006, 03:16 AM
  3. Phone Control (Phoco) and Internet
    By pshadwick in forum Wireless Communications
    Last Post: 04-05-2006, 04:34 PM
  4. AMD’s Personal Internet Communicator brings the Internet to the people >
    By babas151 in forum General Hardware Discussion
    Last Post: 10-25-2004, 02:22 PM
