Results 1 to 4 of 4
Thread: Easiest way to determine if there is a closed circuit
    Aug 2006
    Central PA
    I need to determine if two wires are coming into contact with each other. I'm going to be moving my satellite dish back and forth and I plan on using this method to tell the motors when to stop moving one direction. I'll mount one of the wires to a stationary support of the dish and then the other wire to one of the arms that move. When the two come into contact I'd like to be able to do "x".
    What's the easiest way to do this with the brain?
    Constant Bitrate ACCLR8N's Avatar
    Apr 2009
    Davisburg, MI
    One wire from FB 5V out pin, the other AIN. Create a logic statement when the input goes high, do "x". Better to position a switch instead of running two wires together. Best would be to have arm move a linear resistor. Then you could setup a voltage divider and know where the dish is rather than only when it is at a certain point.
    FLAC Mickz's Avatar
    Sep 2009
    Australia
    Quote Originally Posted by scotty562 View Post
    You need a micro switch (weather proof if outside) the moving arm contacts the lever on the micro switch and closes the circuit. Two wires being pushed or touched together will not work reliably.
    Palm sized ainol MiniPC, 8" Transreflective PRO, Win10, Reverse camera, Dual 10HZ GPS RX's for Speed Display & Sat Nav, FM-DAB & Phone Modules, iDrive interface. T-Screen HVAC control, custom microcontrollers, microcode and FE.
    Aug 2006
    Central PA
    Thanks guys.
  1. easiest way to build this circuit?
    By scott_fx in forum Hardware Development
    Last Post: 05-07-2011, 04:52 PM
  2. How to determine skinpath in a plugin
    By obrienj in forum Road Runner
    Last Post: 06-09-2010, 02:28 PM
  3. Replies: 4
    Last Post: 06-06-2010, 03:19 PM
  4. Best way to determine wattage?
    By maxxell in forum General Hardware Discussion
    Last Post: 04-21-2005, 06:38 PM
  5. How to determine your LCD/Backlight nit value
    By SillyClown in forum LCD/Display
    Last Post: 10-10-2002, 08:24 PM
