Page 4 of 4 FirstFirst 1234
Results 31 to 37 of 37
Thread: I need relays, lots of em! Options? Relay Board Help
  1. #31
    Jun 2004
    Quote Originally Posted by 2k1Toaster View Post
    The parts on there are mini screw terminals to go with the mini theme.
    It is a 2 screw terminal block with side entry, not top down, and a barrier inbetween. Rated for 17.5A which match the relays, and it is still way more than probably 95% of the people need. Datasheet says 12awg down to 30awg will fit in the hole.
    Exactly what I'd want.
  2. #32
    MySQL Error scott_fx's Avatar
    Dec 2004
    Los Angeles Ca
    if these are close to being made, or if you need someone to bite the bullet on a beta. i think i may be interested in this.
    New System in progress:
    M10k
    Phaze TD1500 ~> Seas g18rnx/p
    Zapco Ref 500.1 ~ 12" tc-9
    Transflective Xenarc
    My Car Pc Install
    My Boat Pc worklog
  3. #33
    Mar 2006
    Colorado, but Canadian!
    I just had a panel made and there wasn't room for this design. I am having another panel made tuesday, I will make it fit.
    1.9in x 2.9in -- 47mm x 73mm
  4. #34
    Apr 2006
    Sydney, Australia
    I too am looking for something similar, i will PM u
    Cheers
    Kosti
    New Car PC Build list in progress
  5. #35
    Mar 2006
    Alright, it appears it works. Instead of making the relay boards I used the exact circuit on another board and it worked fine.
    So if there is interest, I will get a small run of them professionally manufactured.
  6. #36
    Mar 2006
    I got the actual PCB back from the factory, I will try to populate them this week and post some pics.
  7. #37
    Mar 2006
  1. lots and lots (and lots) of power
    By cheshirekow in forum Newbie
    Last Post: 04-06-2011, 08:28 PM
  2. What relays to use?
    By Dutch2 in forum Hardware Development
    Last Post: 02-12-2007, 01:10 PM
  3. Mouse options: touchpad versus other options
    By Brycestro in forum Newbie
    Last Post: 01-15-2007, 12:35 PM
  4. FS: Tons of parts, relays, cables, power equipment, LOTS OF STUFF!
    By schapman43 in forum Classified Archive
    Last Post: 09-02-2005, 03:58 PM
