Results 21 to 30 of 38
Thread: Fusion Brain Version 6 -- Firmware Update Version 2.0A
  1. #21
    Mar 2006
    Colorado, but Canadian!
    Quote Originally Posted by dscustoms View Post
    Perfect! Works great on my LED test bed, now I can rebuild my dashboard LED system with proper dimming!!! I've been soldering all night, extending the LCD from my HVAC control unit, extending the two halves of the control unit so that my buttons would be accessible in the glove box and to the FB. (original buttons were carbon contacts on ribbon...) Here's a pic of half of it. My hands hurt.
    I think you need more wires!
    I suggest some sort of insulating goo (like hot glue) to cover all the exposed contacts once you are done. A few thousand miles with RoHs compliant solder will probably mean fragile or broken joints if that is the only thing holding it up. Prepare for the worst.
    1.9in x 2.9in -- 47mm x 73mm
  2. #22
    Feb 2002
    Oh, of course. That wasn't done, I had just burned my fingertips so much that I gave up for the night. It was also 3 am!
    This is how the display side looks, individual heat shrink, supporting plastic sheet with hot glue
    Old School MP3CAR.com member!
  3. #23
    Mo' Programming Mo' Problems
    Sonicxtacy02's Avatar
    Woodbridge, VA
    Blog Entries
    55
    hmmm with this latest firmware i can no longer connect via VCP. In hyperterminal it tells me unable to connect to Com Port. Check Settings. Tried other programs and its the same thing. Any ideas? This is a win 7 64bit system. Latest FuseGuide still works. I've tried powering off.. redoing the firmware, pc reboot, and fiddling with the port settings.
    Live mp3Car Facebook Chat
  4. #24
    Mar 2006
    Quote Originally Posted by Sonicxtacy02 View Post
    I think that is something else going on. Perhaps the golden reboot? I think dscustoms and I can connect ok. If you had the COM port running/active when you switched into bootloader mode, windows doesn't like that and probably locked that port.
  5. #25
    Woodbridge, VA
    Blog Entries
    55
    Quote Originally Posted by 2k1Toaster View Post
    I didnt have any terminal programs running this morning doing the firmware update, and i've tried to change the com port number and its the same thing. I'll have to try on another PC i guess
  6. #26
    Mar 2006
    Have you restarted since?
  7. #27
    Mar 2006
    And it is possible the flash went badly. So you may want to reflash it just incase.
  8. #28
    Woodbridge, VA
    Blog Entries
    55
    Have restarted multiple times and reflashed again too.
  9. #29
    Feb 2002
    I'm using win7 x64 as well, and have no issues with hyperterminal and either of my fb units with the latest (or any) firmware.
  10. #30
    Woodbridge, VA
    Blog Entries
    55
    Something else i notice. after jumping the reset pins for a second these events do not happen
    • After some time (many seconds) they will stop blinking back and forth and you should see the Fusion Brain connect to your PC as a bootloader device
    • If you do not have the drivers installed, they will automatically be downloaded from Windows Updates
    • Once the device is attached and the drivers are functioning you should see it listed as a "Custom USB Device" in Device Manager
    • Open up the bootloader application
    • You should see it say "Connected"
    On mine after resetting there are two sets of leds that dance around for about 5 seconds. Then one stops (if looking at the FB and the USB and power plug are on bottom, the 3rd one from the bottom stays solid green and the bottom two leds still continue to dance). Windows never goes to install the custom usb device. It looks as if it installs a usb input device, but its kinda hard to tell ... i have so many of them. If i open the bootloader, it says device attached, not connected.
    EDIT
    Just checked.. in reset mode windows installs the FB as a HID-compliant device.
  1. ** NEW Fusion Brain Version 6, Pre-Order NOW **
    By 2k1Toaster in forum Fusion Brain
    Last Post: 04-07-2013, 03:48 PM
  2. Fusion Brain version 4
    By MattFreitag in forum Fusion Brain
    Last Post: 08-01-2010, 05:32 PM
  3. Closeout Sale -- Fusion Brain Version 3 $22-$30
    Last Post: 06-30-2009, 03:36 PM
  4. Fusion Brain Version 4 Manual
    By greenman100 in forum FB Documentation and Tutorials
    Last Post: 12-19-2008, 03:11 PM
  5. Custom Firmware for Fusion Brain
    By fermentation in forum Fusion Brain
    Last Post: 02-11-2008, 11:34 AM
