Page 4 of 4 FirstFirst 1234
Results 31 to 37 of 37
Thread: Fusion Brain Version 6 -- Firmware Update Version 2.0A
  1. #31
    Mo' Programming Mo' Problems
    Sonicxtacy02's Avatar
    Woodbridge, VA
    Blog Entries
    41
    Good News/Bad News. Bad news is i cant for the life of me connect to the com port on my dev PC. Good news is it works on my home PC. Any idea how i can completely remove the drivers used and start over. If not i'm coding in the dark!
    Live mp3Car Facebook Chat
  2. #32
    Low Bitrate UniqelyCommon's Avatar
    Nov 2008
    Look behind you.
    Quote Originally Posted by Sonicxtacy02 View Post
    EDIT
    Just checked.. in reset mode windows installs the FB as a HID-compliant device.
    That's all I had, too. The bootloader program told me the device was connected, though. Exported the original Hex (just in case) and then flashed. Opened a terminal and received the expected responses to commands.
  3. #33
    Nov 2008
    Look behind you.
    If you already know this (likely so) just ignore me
    In the Device Manager, I've right-clicked a device and selected Uninstall, then was prompted if I wanted to remove the driver as well.
  4. #34
    Feb 2012
    Chattanooga, TN
    I'm having issues with trying to get Fusion Brian to be displayed as a Com port.... I have done the steps to reset FB but one light will continue to blink back and forth, FB will then be displayed under HID in the device manger. The bootloader will work and I can flash a new hex file but I cant connect to the FB through a hyperterminal program since it still wont show up as in the com ports on my computer. I'm on windows 7 btw. Some guidance...
  5. #35
    Mar 2006
    Colorado, but Canadian!
    Quote Originally Posted by sdhsbaseball View Post
    After you program it, you need to power reset it. Meaning unplug it from all power!
    If it is showing up as a HID device, you aren't doing that.
    1.9in x 2.9in -- 47mm x 73mm
  6. #36
    Feb 2012
    Chattanooga, TN
    I should have been more clear, I am unpluging FB from the USB drive after the writing of the hex file. When I plug it back in after wait 30seconds it will show up in its on expandable section in the device manger with the title of unkown device. Then inside the unknown device section it has two FB titles that i cant remember right this second.
    So in other words I have done what you have suggested but it didnt work.
  7. #37
    Mar 2006
    Unknown device is not a HID device. This is different then your last statement. And actually it means that it is doing exactly as it should. The FB is recognized as 2 devices (as it should be). Now you actually have to tell your computer what those devices are, meaning you need to install the drivers for each one. Download the drivers, and install them. The Fusion Brain is no different then any other device in that you need drivers for it. The difference is that Microsoft doesn't bundle these drivers within Windows.
  1. ** NEW Fusion Brain Version 6, Pre-Order NOW **
    By 2k1Toaster in forum Fusion Brain
    Last Post: 04-07-2013, 02:48 PM
  2. Fusion Brain version 4
    By MattFreitag in forum Fusion Brain
    Last Post: 08-01-2010, 04:32 PM
  3. Closeout Sale -- Fusion Brain Version 3 $22-$30
    Last Post: 06-30-2009, 02:36 PM
  4. Fusion Brain Version 4 Manual
    By greenman100 in forum FB Documentation and Tutorials
    Last Post: 12-19-2008, 02:11 PM
  5. Custom Firmware for Fusion Brain
    By fermentation in forum Fusion Brain
    Last Post: 02-11-2008, 10:34 AM
