Done! How can I verify new firmware installed?
Bootloader Application: http://www.fusioncontrolcentre.com/F...bootloader.exe
New Firmware -- Version 2.2A: http://www.fusioncontrolcentre.com/F...013___2_2A.hex
Steps:
- Download the bootloader application from above
- Download the new firmware from above
- Plug in your Fusion Brain Version 6 via USB
- Short the RESET pins together using a metallic object being careful not to short anything else. The use of a 0.1" jumper is recommended, but a screwdriver works just as well. The RESET pins are the 2 pins that are vertical between the USB jack and the analogue input pins on the USB and power jack side of the board
- You should now see lights sort of blink back and forth on the only horizontal row of digital outputs (24-31)
- After some time (many seconds) they will stop blinking back and forth and you should see the Fusion Brain connect to your PC as a bootloader device
- If you do not have the drivers installed, they will automatically be downloaded from Windows Updates
- Once the device is attached and the drivers are functioning you should see it listed as a "Custom USB Device" in Device Manager
- Open up the bootloader application
- You should see it say "Connected"
- Choose "Open Hex File"
- Select the firmware that you downloaded
- Choose the "Program/Verify" button
- Wait for all the messages to stop and it to display finished
- Unplug and completely de-power the Fusion Brain Version 6. No lights should be lit
- Calmy count to 2 to give the board a chance to fully die. The filtering caps try to keep it alive even without power for a good time.
- Then plug it back in and it should be updated and back to normal. If not, then go back to shorting the RESET pins and reload the firmware. I have never had the firmware fail to load however, so if this happens please let us know.
1.9in x 2.9in -- 47mm x 73mm
Old School MP3CAR.com member!
Use the COM port and see if "a?" and "A?" work
Actually I am going to add a firmware revision to the firmware.![]()
Inputs work in hyperterminal! thanks!
Can I play with PWM in hyperterminal yet? Outputs ALWAYS flash, still. btw
Ok now the firmware update (http://www.fusioncontrolcentre.com/F...20_05_2011.hex) now has Firmware revision and update date. To check revision after downloading, use the COM port and send a "*IDN?" request. You will now see something like:
Code:>*IDN? *IDN? Fusion Brain Version 6 Fusion Control Centre www.FusionControlCentre.com SN: -1077923856 Firmware Revision: 1.2 Firmware Date: 20-05-2011
Updating AGAIN..
*IDN?
SN: -1077923856
