I guess these are not important enough questions to be answered ?!?
Why isn't the mentioned case for the FB6 in the store?
Why isn't there detailed spec sheets or documentation for FB6?
Why isn't there a spec sheet for the freq-volt converter?
Will the freq-volt converter work with the FB6 3.3v inputs?
Will the input isolator/voltage divider work with the FB6 3.3 inputs?
TruckPC - gutted, being used for test setup
BoatPC - Update coming this spring
BlazerPC - PS keeps killing battery
You should post these questions in the V6 thread that is already started. http://www.mp3car.com/fusion-brain/1...order-now.html
Love
Because mp3car hasn't bought any from me yet.
The forums and email are the spec sheet. If you have an actual question I try to answer it as soon as I see it.
[/quote]
It is 210Hz/volt at 5v, and 310Hz/volts at 3.3v. Equation is: Vout = Vin * R1 * C1 * Fin ==> Vout = (3.3 *100000*.01*(10^-6) * FREQUECY)
Yes all sensors except the ultrasonic will work with the FBv6.
They are but I didn't see them. I try to answer once I see the question. I am doing this solo now.
Or at least a question with a link to a new thread. If you make a new thread that I have no subscription to, then I only get an email once a day at night. I may miss that. If you post it in a thread I have a subscription in (like one I made) then I get an email instantly. Also everyone else who has subscribed to that thread with alerts on gets an email and might be able to help.
1.9in x 2.9in -- 47mm x 73mm
Thank you for the answers, I would like to know the max input voltage on the freq-volt converter.
