Results 21 to 30 of 31
Thread: NEW fusion brain user! help
  1. #21
    Mar 2006
    Colorado, but Canadian!
    What "fusion demo" where it is stable?
    1.9in x 2.9in -- 47mm x 73mm
  2. #22
    Feb 2010
    i mean in mdx when an output trigger relay ....10 seconds after that it start click lets say once every 6 sec ,, while in fusion demo it stable no clicking
    and about the voltage ..i connect it in car the car voltage is 13.80 while in the output is 12.75 the same happen in car as home ,, 1 voltage drop ...
  3. #23
    Mar 2006
    Yes, but what is "fusion demo". I have made no such creature.
  4. #24
    Feb 2010
    opps i mean fusion brain demo application
  5. #25
    Feb 2010
    so what the problem!
  6. #26
    Mar 2006
    Quote Originally Posted by mgd95 View Post
    No idea. Some people seem to have this problem, most (including myself) don't. I have no idea why. All I know is that I can never make it happen. If you are using RR or CF, then try RRFusion or CFFusion. Since it seems to work with one software and not the other, then perhaps there is some software difference. I have been looking for hardware faults and have never found anything. This is the first I have heard of it working with one program and not the other.
  7. #27
    Feb 2010
    ok!... how about the voltage drop problem [ no idea too ]...but there another problem that u miss in early post ,i have told u that when connecting a relay with a long cable [1m] the software freeze .to back to normal i have to disconnect power from fb. i will be using centrafusion ,, funny same problem /..and both fusion demo and centrafusion share the same vb code...i am taking to Sonic to see the problem form his side,, Your Last Post confirm me that there No hardware problem at all...Right .... Thx.
  8. #28
    Feb 2010
    so its not a hardware problem ..... i think i will put this board in a box and throw it away,,, thanks for ur time...
  9. #29
    Feb 2010
    last thing :
    1] voltage drop [ 1 volt ]
    2] software freeze with long cable to the realy [ 1m cable]
    = Bad luck....Right
  10. #30
    Mar 2006
    I have relays running on 10m cables, no issues.
    It's not bad luck, there is something wrong. And it appears to be software configuration.
  1. Turn on a Light Bulb using Road Runner Fusion Brain and Road Runner Fusion Document
    By Batmaninls in forum FB Documentation and Tutorials
    Last Post: 07-12-2010, 09:06 PM
  2. fusion brain help
    By anam_funny in forum General Hardware Discussion
    Last Post: 01-29-2009, 09:20 AM
  3. New Fusion Brain User. Digital Input Question...
    By josh14w in forum Fusion Brain
    Last Post: 12-02-2008, 01:37 PM
  4. User Manual for Fusion Brain
    By greenman100 in forum Fusion Brain
    Last Post: 07-07-2007, 12:31 PM
Tags for this Thread
