Results 1 to 4 of 4
Thread: fusion brain and riderunner
    MySQL Error scott_fx's Avatar
    Dec 2004
    Los Angeles Ca
    right now i'm using a set of mjs usbio1's and they have been so easy to implement into my ride runner skins. I've been looking around and havent found any documentation on how to incorporate fusionbrain into the exectbl in riderunner. for example. i created a button on my menu.skin that could toggle one of the relays.
    this is how i do it (in the execTBL) with usbio1:
    Code:
    ”MJSGIO_SETRELAY;1;1;2”
    this will set the first board's relay #1 to toggle on and off
    if i just want it to just turn on the relay id do this:
    Code:
    "MJSGIO_SETRELAY;1;1;1"
    and to just turn it off i'd do this:
    Code:
    "MJSGIO_SETRELAY;1;1;0"
    is this something that is easy to do with fb? if so, can someone give me an example?
    New System in progress:
    M10k
    Phaze TD1500 ~> Seas g18rnx/p
    Zapco Ref 500.1 ~ 12" tc-9
    Transflective Xenarc
    My Car Pc Install
    My Boat Pc worklog
    Mar 2006
    Colorado, but Canadian!
    It helps when you are the creator of the software and the hardware. Mitch is close with RR and it shows.
    I would talk to Sonic about RRFusion, it sounds like what you are looking for.
    1.9in x 2.9in -- 47mm x 73mm
    Dec 2004
    Los Angeles Ca
    how did i miss that. i may finally bite the bullet! fb has always scared me, this makes it a lot easier
    M10k
    My Car Pc Install
    My Boat Pc worklog
    Mar 2006
    Quote Originally Posted by scott_fx View Post
    I would PM him or make a new thread or just search to verify it is FBv6 compatible. I sent him one for free so he could get it up and running, and I think he had it working but you may want to confirm if this is important to you as like I said, I don't support it.
  1. Just go my fusion brain
    By themlruts in forum Fusion Brain
    Last Post: 11-22-2010, 08:30 PM
  2. Turn on a Light Bulb using Road Runner Fusion Brain and Road Runner Fusion Document
    By Batmaninls in forum FB Documentation and Tutorials
    Last Post: 07-12-2010, 09:06 PM
  3. help with fusion brain
    By menthos in forum FB Software
    Last Post: 06-15-2009, 08:28 AM
  4. fusion brain help
    By anam_funny in forum General Hardware Discussion
    Last Post: 01-29-2009, 09:20 AM
  5. Fusion Brain and its uses!
    By HiJackZX1 in forum Fusion Brain
    Last Post: 06-08-2008, 06:41 PM
