Results 1 to 2 of 2
Thread: Lighting Timers
    Mar 2008
    Lighting Timers
    Hello I was wondering if anyone had used the fusion brain for home lighting? I would like to be able to set the lights on timers, is this possible? Would anyone be willing to help work on this? it would be very useful for me.
    Mar 2006
    Colorado, but Canadian!
    Quote Originally Posted by ouellettesr View Post
    You may want to check the Homeseer (sp?) forum. There is a guy on there who has made a plugin to homeseer for the fusion brain. But if all you want is home automation, then there may be a more all-in-one packaged solution those forums may lead you to as well. Just depends on your skill level and what your end goal is.
    But to answer the question, the FB can definitely be used for controlling lights or any signal like that through the appropriate relay and wiring.
    1.9in x 2.9in -- 47mm x 73mm
  1. Fade in & out of interior lighting / dome lighting?
    By TheGuv in forum Hardware Development
    Last Post: 10-10-2011, 10:18 PM
  2. Odometer output and timers
    By ACCLR8N in forum FB Software
    Last Post: 12-29-2009, 07:45 PM
  3. IR lighting for a car this any use?
    By mrcgibb in forum General Hardware Discussion
    Last Post: 07-12-2008, 08:45 AM
  4. In car lighting....
    By KiCe in forum General Hardware Discussion
    Last Post: 06-28-2005, 03:54 PM
  5. Lighting Effects
    By Cat in forum General Hardware Discussion
    Last Post: 06-27-2005, 09:49 PM
