New Fusion Brain Setup Questions
So for Christmas, I am looking to get a FB to add to my setup. Questions below.
Fusion Brain Version 6 x1
50A Current Sensor x4
MOSFET Power Output Board x2
4 Channel Input Isolator and Voltage Divider x1
Photosensor x1
Thermometer x2
Fusion Control Centre's Mini-Relay Board x1
General Requirements:
Current sensors for processor, 2 amps, and carPC.
Temps inside amp rack and trunk
Light gauge for screen auto-dimming
Remote for processor and sub amp to make anti-thump and battery saver
Remote and Fan controlled for 2 fan rigs (1 4xfan set for amp rack / 1 2xfan set for cooling the trunk)
Voltmeter for audio gear
On/Off for some led lighting (Provide light for adjusting gains and other amp settings)
Detailed Requirements:
1) If dark dim screen, else brightness high (may add variable adjustment setting after initial setup and if needed)
2) If (voltage>12v && sound card on) turn ON processor remote
else turn off processor remote
3) If (voltage>12.5v && processor remote ON)turn off sub remote
else turn off sub remote
4) If (amp rack temp > X degrees) turn ON rack fans HIGH
else turn ON rack fans LOW
5) If (trunk temp > Y degrees) turn ON trunk fans HIGH
else If (trunk temp > z degrees) turn ON trunk fans LOW
else turn OFF trunk fans
6) Log amperage usage of all 4 components separate and the system combine
Questions:
1) Can this hardware support the requirements I am looking to accomplish? (from what i can tell yes)
2) How hot does the fusion brain get? I am changing my case to a Silverstone SG-08 and I would like to mount most of the hardware in the spare 3.5 HDD and 2.5 HDD bays. If these generate too much heat, I will need to redesign my intended setup.
3) How much power does the FB use? The fans and remotes shouldn't draw much off the FB so overall I would assume this setup shouldn't use more than 60w.
4) Is it best to power the FB off a direct dc line or rig to the cpu psu? If wired directly, will it be always on?
5) Is there anything else I may need? I was reading I may need resistors to create a voltmeter.
6) (Dumb question and pretty sure I can get this working without seeing it) Using RR / FB, can I have manual overrides for all automated tasks? For instance on a hundred degree day, I may want to default to fans always on. Or I may want to turn the sub off even though power in not an issue.
Thanks in advance for any help.
