Results 1 to 6 of 6
Thread: 5 Rin Relays
    Feb 2011
    MD
    5 Rin Relays
    Can I control a 5 pin relay with a fusion brain? I am considering doing the Honda ELD bypass mod ( http://forum.sounddomain.com/ubbthre...page/0/fpart/3 half way down page). If I can use that type of relay, will try and figure out how to code it automated. Thanks.
    Mar 2006
    Colorado, but Canadian!
    A 5pin relay is NO-COM-NC and 2 coils. That is a standard relay, exactly what the FB is designed for.
    1.9in x 2.9in -- 47mm x 73mm
    Raw Wave
    Nov 2009
    "two coils" meaning 2 terminals for the coil.
    We know what the Toaster meant.
    Does the FB require spike protection? I'd assume so - ie, the diode across the coil - Anode (non-lined) end to coil GND, Cathode to coil+.
    Mar 2006
    Quote Originally Posted by OldSpark View Post
    Correct, I should have been more explicit.
    Legal mumbo jumbo from me as Fusion Control Centre: Yes
    Me as me: Not always.
    The relays I sell specifically for the FB, have no protection diode. But they are also low current and made to minimize spiking on coil release. If you use a standard beefy automotive relay or just whatever you have lying around, I do recommend a supression diode. The Mega and Mini Relay boards have diodes just because it is on a board, and might as well. The FB's FETs are rated to handle high voltage spikes for limited times, so it all works without suppression diodes for what I sell (FB + FB Relays). When you DIY, your FB's life is in your own hands.
    Raw Wave
    Nov 2009
    That's the beauty of the FB - just buy the RB relay boards. (And sue the designer if they blow ha ha.)
    Maybe the FB uses a line drivers (like the ULN2003?? - essentially transistor buffers) that some use. They tend to be quite robust.
    I'd say if ever in doubt. add the diode. A mere 20c IN4004 or iN4007 etc could prevent the rear ends of uPC and digital things from blowing. (Relay coils can induce up a a -200V spike, typically 50V-100V are common. Digital circuit typically only tolerate -0.3V to -0.6V.)
    But to that I say add it yourself - I don't like relays with inbuilt diodes, I prefer to add my own externally (to the relay base) - in part just in case I was 85 as more +ve then 86. (By convention, relay coils are 86 = +ve, 85 = -ve, hence the diode line end (Cathode) towards 86 +ve).
    I just didn't want to see a Fusion Brain get fused.
    Mar 2006
    Each output pin goes through 2 large NPN transistors in a darlington formation between the MCU and the relay coil. You will blow an output driver before harming the MCU, which is a good thing. The older versions went through shared darlingtons. So if you blew it, you might blow 8 channels at a time.
  1. Relays
    By FusionFanatic in forum VaultWiki
    Last Post: 09-24-2009, 07:19 AM
  2. What relays to use?
    By Dutch2 in forum Hardware Development
    Last Post: 02-12-2007, 01:10 PM
  3. Help Me With Relays
    By Redian in forum General Hardware Discussion
    Last Post: 08-07-2006, 01:50 AM
  4. New to relays and ATX PSU
    By masch in forum Power Supplies
    Last Post: 05-20-2004, 01:51 PM
  5. Relays..
    By unrealer33 in forum Power Supplies
    Last Post: 06-11-2003, 06:59 AM
