Results 1 to 4 of 4
Thread: Configurator wont load
    Constant Bitrate KennyKen's Avatar
    England
    Hi All
    I am just getting back into this after a few years out and after re-downloading the software and installing it, the Fusion Control Centre Uber MDX edition loads fine, but the Fusion Control Centre Configurator will not load, i get the following error:
    FCC Uber MDX Configurator has stopped working
    Any ideas?
    I am currently running windows 7 - 32bit
    I have all required .net versions and DirectX
    I installed version 4.0 and that then got updated by the auto updater
    the hardware i have is version 3 or 4, i cant remember right now but i'm not even plugging that in yet...
    Thanks in advance
    Ken
    Prepping for Trax in september
    Re-Building the whole CarPC to upgrade all the software
    Whole new boot build and moulding my screen into the dash...Again
    Jun 2004
    you might try attaching the brain & loading the drivers, the configurator may look at the driver for some reason. been a long time since I've used MDX.
    Mar 2006
    Colorado, but Canadian!
    Quote Originally Posted by KennyKen View Post
    Hi All
    Any ideas?
    Thanks in advance
    Ken
    First thing to check is you run it as an administrator if you have UAC enabled.
    Quote Originally Posted by Iamthehor View Post
    MDX is dead essentially.
    1.9in x 2.9in -- 47mm x 73mm
    England
    Quote Originally Posted by 2k1Toaster View Post
    Bingo - Thats sorted it :-)
    I should have thought of that myself really, Thanks anyway!
  1. RR wont load
    By eagleslayor in forum RR Bug Tracker
    Last Post: 08-22-2007, 01:38 PM
  2. DAM OS Wont Load
    By arawas in forum Software & Software Development
    Last Post: 01-17-2006, 04:43 PM
  3. Navivoice 1.7 wont load
    By brandonn in forum PowerVoice
    Last Post: 01-13-2006, 01:03 AM
  4. Wont load!!!!!
    By bobbykokinos in forum Media Engine
    Last Post: 03-24-2004, 11:52 PM
