Results 1 to 6 of 6
Thread: Need help with an anlog sensor
    Jul 2009
    Squamish, BC
    I have a FB4 connected to an oil pressure sender.
    The sender was three wires; 12V power, GRND and signal 0-5V
    I have connected power and ground to a power and ground not on the board.
    That leaves one wire only going to the brain's analog input signal.
    I'm not reading any values on the input.
    Do I need to connect the FB input ground to GRND?
    Can I connect the sensor GRND to the FB input?
    MySQL Error scott_fx's Avatar
    Dec 2004
    Los Angeles Ca
    check it first with a dmm to make sure your sender is outputing a voltage
    New System in progress:
    M10k
    Phaze TD1500 ~> Seas g18rnx/p
    Zapco Ref 500.1 ~ 12" tc-9
    Transflective Xenarc
    My Car Pc Install
    My Boat Pc worklog
    Jul 2009
    Squamish, BC
    I have and it is. Reading was about 4.7V
    Dec 2004
    Los Angeles Ca
    im not familiar with the fb, but arduinos normally need a common ground.
    M10k
    My Car Pc Install
    My Boat Pc worklog
    Jul 2009
    Squamish, BC
    The FB and the sensor share the same ground (the car) but the input ground is not connected to anything.
    The easiest connection would be to connect the sensor ground to the FB input ground but as it is powered from 12V I'm reluctant to try that in case it fries something.
    Dec 2004
    Los Angeles Ca
    check out this link:
    http://arduino.cc/forum/index.php/topic,12893.0.html
    looks like you may just need a zener diode
    M10k
    My Car Pc Install
    My Boat Pc worklog
  1. CTS/ATS Sensor
    By bobyjo in forum Engine Management, OBD-II, Engine Diagnostics, etc.
    Last Post: 04-20-2009, 10:46 AM
  2. water sensor
    By scott_fx in forum FB Sensors
    Last Post: 01-15-2009, 12:25 PM
  3. Bad sensor?
    By ctsoccer13 in forum Fusion Brain
    Last Post: 09-23-2008, 10:38 PM
  4. EGT Sensor
    By thwack in forum Fusion Brain
    Last Post: 11-09-2007, 11:43 AM
  5. sensor
    By llmask in forum General MP3Car Discussion
    Last Post: 03-21-2004, 09:10 PM
