Results 1 to 3 of 3
Thread: Almera n16 pc
    Oct 2011
    Almera n16 pc
    Hi,
    I would like to install a car pc in me vehicle, but i find one problem. As you can see on the pic below i already have a display (as far as i know vfd display) which shows all the data from climate control, outside temp, radio etc. I would like to remove it and put touch panel instead with car pc. The problem is how to get all those info from this display to a pc and then to a new display? i dont wan to control hvac with touch panel cause its done with a centre console which also operates radio. Any ideas, suggestions?
    thanx
    Mar 2006
    Colorado, but Canadian!
    If you just want to display and not control, then that is a simple job. Each of those VFD or LCD segments has a pin. Or worst case it is a matrix. The logic would be to just check when that segment is told to go high, and then display whatever on screen what the combinations of segments light up.
    1.9in x 2.9in -- 47mm x 73mm
    Oct 2011
    well how to figure out if its a matrix or not? all i know from manual is that the display is connected to radio, combination meter, multi function switch and ac - auto amp and has 24 pins (if not mistaken) if its any help i can insert pics from manualName:  el1.jpg
Size:  171.2 KBName:  el 2.jpg
Size:  117.7 KBName:  el 3.jpg
    thanx for any help
  1. almera n16 car pc
    By bobekdobek in forum Newbie
    Last Post: 10-24-2011, 03:02 AM
  2. OBD2 connector in NISSAN ALMERA
    By proyectanteATE in forum Engine Management, OBD-II, Engine Diagnostics, etc.
    Last Post: 04-08-2011, 04:39 AM
  3. Nissan Almera N15 project
    By dudeness in forum Show off your project
    Last Post: 04-23-2007, 07:12 AM
  4. filjoa CarPC Nissan Almera
    By filjoa in forum Show off your project
    Last Post: 05-24-2006, 04:40 AM
