Results 1 to 2 of 2
Thread: Need help with my fusion brian
    Oct 2012
    Gillette, Wy, USA
    I am new to the whole Fusion Brain stuff, and have recieved a fb v6 that I ordered a few days ago. I have been trying to get it setup to run under Ubuntu 12.04 with no luck. I tried following Fusion Brain program for Linux, but I keep getting some errors. I have also tried as said here, Fusion Brain Version 6 -- Beta Testing, but it responds
    Code:
    adam@adam-Presario-CQ57-Notebook-PC:~$ dmesg | tail
    [   23.742600] atkbd serio0: Unknown key pressed (translated set 2, code 0xab on isa0060/serio0).
    [   23.742612] atkbd serio0: Use 'setkeycodes e02b <keycode>' to make it known.
    [   23.746336] atkbd serio0: Unknown key released (translated set 2, code 0xab on isa0060/serio0).
    [   23.746351] atkbd serio0: Use 'setkeycodes e02b <keycode>' to make it known.
    [   46.356272] usb 3-1: new full-speed USB device number 2 using ohci_hcd
    [   46.679572] cdc_acm 3-1:1.0: This device cannot do calls on its own. It is not a modem.
    [   46.679586] cdc_acm 3-1:1.0: Control and data interfaces are not separated!
    [   46.679701] cdc_acm 3-1:1.0: ttyACM0: USB ACM device
    [   46.686315] usbcore: registered new interface driver cdc_acm
    [   46.686325] cdc_acm: USB Abstract Control Model driver for USB modems and ISDN adapters
    adam@adam-Presario-CQ57-Notebook-PC:~$ echo *IDN? > /dev/ttyACM0
    bash: /dev/ttyACM0: Permission denied
    adam@adam-Presario-CQ57-Notebook-PC:~$ sudo echo *IDN? > /dev/ttyACM0
    adam@adam-Presario-CQ57-Notebook-PC:~$ ls -l /dev/ttyA*
    crw-rw---- 1 root dialout 166, 0 Oct 28 15:55 /dev/ttyACM0
    I have been around linux for a few years but have never needed to to any programming outside of minor html/php, and a couple quick shell scripts to to some automatic stuff. The FB will eventuly go in my car when I get enough money for more stuff. I am hoping to use Ubuntu 12.04 or another LTS that they have when i install it, but am willing to use another linux OS if needed.
    Mar 2006
    Colorado, but Canadian!
    Quote Originally Posted by fredf07 View Post
    Code:
    Are you wanting to use bulk USB, or USB-Serial?
    1.9in x 2.9in -- 47mm x 73mm
  1. ** NEW ** Fusion Control Centre's Fusion Volume Knob!
    By 2k1Toaster in forum FB Sensors
    Last Post: 05-04-2013, 09:25 PM
  2. HVAC help with Fusion Brian
    By jabz in forum Fusion Brain
    Last Post: 07-17-2011, 02:39 PM
  3. Help Needed with Fusion Brian Programming
    By jeffkay in forum Fusion Brain
    Last Post: 04-16-2009, 06:14 PM
  4. mp3Car.com interviews Brian Palmer - Iphone engine performance
    By Fiberoptic in forum Mp3Car Blog Talk
    Last Post: 11-24-2008, 11:51 AM
  5. FS Alpine IVA D300 brian
    By E-Z-OUT in forum Classified Archive
    Last Post: 06-05-2006, 03:01 PM
