The version is good, and the files are good. I am reuploading the update. Maybe the update didn't get pushed properly. Testing it on my end in a clean folder, it works.
Fusion Control Centre -- FuseGL {1.1.0.471}
Trace Output File
In that folder I have a few items and folders...
Config (folder)
FB Details (folder)
images (folder)
Logic (folder)
FuseGL.exe
FuseGL_AutoUpdater_Log.txt
FuseGL Trace.txt
1.9in x 2.9in -- 47mm x 73mm
That newest update seems to be working for me.
Ok great. Do you see the big ugly white box and can you can cycle through?
Yep, and it cycles through as I click, and I can see the LEDs change with the new output. Now I'm trying to figure out how to edit this to make it simply monitor the digital port, and if port 0,0 is on display LowOn image, and if its off display LowOff, then for port 0,1 it would be MediumLowOn etc. I added those speeds in the section under Setup FanSpeed textures and ports but I think that just broke it. lol
In my setup I have each fan speed as a seperate button, and I have 1 button set to turn it all off. if that makes sense.
Just think it through. Adding to the Fan Speed enumeration is a great idea. But if you have 7 speeds and 7 buttons, you will need 7 FGLO inputs. I would tie all of the click events to a single method. Then have one spot with all your logic. It is the least efficient way of doing things, but conceptually the simplest. Instead of having one response for everybutton, you have 1 response for all the buttons.
Yeah, I think I have it added in 3 areas, I'll post my code below. Not sure if my error is in here somewhere, or in the xml file.
using System;
using System.Collections.Generic;
using System.Linq;
using System.Text;
using FB_USB_2011;
using FuseGL.GUI;
namespace HVAC_Example
public class HVAC_Example
public enum FanSpeed
OFF,
LOWON,
LOWOFF,
MEDIUMLOWON,
MEDIUMLOWOFF,
MEDIUMHIGHON,
MEDIUMHIGHOFF,
HIGHON,
HIGHOFF
internal class MyInternalHVAC_FanSpeed_Class
public FB_Monitor.DigitalOutputPort DigitalOutputPort;
public FuseGL.GUI.FGLO_Texture FGLO_Texture;
public MyInternalHVAC_FanSpeed_Class(FB_Monitor.DigitalOu tputPort digitalOutputPort, FGLO_Texture fgloTexture)
DigitalOutputPort = digitalOutputPort;
FGLO_Texture = fgloTexture;
internal Dictionary<FanSpeed, MyInternalHVAC_FanSpeed_Class> FanSpeedLookupDictionary = new Dictionary<FanSpeed,MyInternalHVAC_FanSpeed_Class> ();
internal FanSpeed currentFanSpeed = FanSpeed.OFF;
public void setup_HVAC(
FuseGL.GUI.FuseGL_Object displayFuseGL_Object_for_fan_speed,
FB_Monitor.DigitalOutputPort _digitalOutputPort_for_fan_off,
FB_Monitor.DigitalOutputPort _digitalOutputPort_for_fan_lowoff,
FB_Monitor.DigitalOutputPort _digitalOutputPort_for_fan_lowon,
FB_Monitor.DigitalOutputPort _digitalOutputPort_for_fan_mediumlowoff,
FB_Monitor.DigitalOutputPort _digitalOutputPort_for_fan_mediumlowon,
FB_Monitor.DigitalOutputPort _digitalOutputPort_for_fan_mediumhighoff,
FB_Monitor.DigitalOutputPort _digitalOutputPort_for_fan_mediumhighon,
FB_Monitor.DigitalOutputPort _digitalOutputPort_for_fan_highoff,
FB_Monitor.DigitalOutputPort _digitalOutputPort_for_fan_highon
// Setup FanSpeed textures and ports
FanSpeedLookupDictionary.Add(FanSpeed.OFF, new MyInternalHVAC_FanSpeed_Class(_digitalOutputPort_f or_fan_off, FGLO_Texture.MakeQuickFGLOTexture___ConvertFromExt ernalImagePath("HVAC_Fan_Control___FanSpeedImage__ _OFF", "http://www.mp3car.com/vbulletin/images/HVAC/FanSpeed/Off.png")));
FanSpeedLookupDictionary.Add(FanSpeed.LOWOFF, new MyInternalHVAC_FanSpeed_Class(_digitalOutputPort_f or_fan_lowoff, FGLO_Texture.MakeQuickFGLOTexture___ConvertFromExt ernalImagePath("HVAC_Fan_Control___FanSpeedImage__ _LOWOFF", "http://www.mp3car.com/vbulletin/images/HVAC/FanSpeed/LowOff.png")));
FanSpeedLookupDictionary.Add(FanSpeed.LOWON, new MyInternalHVAC_FanSpeed_Class(_digitalOutputPort_f or_fan_lowon, FGLO_Texture.MakeQuickFGLOTexture___ConvertFromExt ernalImagePath("HVAC_Fan_Control___FanSpeedImage__ _LOWON", "http://www.mp3car.com/vbulletin/images/HVAC/FanSpeed/LowOn.png")));
FanSpeedLookupDictionary.Add(FanSpeed.MEDIUMLOWOFF , new MyInternalHVAC_FanSpeed_Class(_digitalOutputPort_f or_fan_mediumlowoff, FGLO_Texture.MakeQuickFGLOTexture___ConvertFromExt ernalImagePath("HVAC_Fan_Control___FanSpeedImage__ _MEDIUMLOWOFF", "http://www.mp3car.com/vbulletin/images/HVAC/FanSpeed/MediumLowOff.png")));
FanSpeedLookupDictionary.Add(FanSpeed.MEDIUMLOWON, new MyInternalHVAC_FanSpeed_Class(_digitalOutputPort_f or_fan_mediumlowon, FGLO_Texture.MakeQuickFGLOTexture___ConvertFromExt ernalImagePath("HVAC_Fan_Control___FanSpeedImage__ _MEDIUMLOWON", "http://www.mp3car.com/vbulletin/images/HVAC/FanSpeed/MediumLowon.png")));
FanSpeedLookupDictionary.Add(FanSpeed.MEDIUMHIGHOF F, new MyInternalHVAC_FanSpeed_Class(_digitalOutputPort_f or_fan_mediumhighoff, FGLO_Texture.MakeQuickFGLOTexture___ConvertFromExt ernalImagePath("HVAC_Fan_Control___FanSpeedImage__ _MEDIUMHIGHOFF", "http://www.mp3car.com/vbulletin/images/HVAC/FanSpeed/MediumHighOff.png")));
FanSpeedLookupDictionary.Add(FanSpeed.MEDIUMHIGHON , new MyInternalHVAC_FanSpeed_Class(_digitalOutputPort_f or_fan_mediumhighon, FGLO_Texture.MakeQuickFGLOTexture___ConvertFromExt ernalImagePath("HVAC_Fan_Control___FanSpeedImage__ _MEDIUMHIGHON", "http://www.mp3car.com/vbulletin/images/HVAC/FanSpeed/MediumHighON.png")));
FanSpeedLookupDictionary.Add(FanSpeed.HIGHOFF, new MyInternalHVAC_FanSpeed_Class(_digitalOutputPort_f or_fan_highoff, FGLO_Texture.MakeQuickFGLOTexture___ConvertFromExt ernalImagePath("HVAC_Fan_Control___FanSpeedImage__ _HIGHOFF", "http://www.mp3car.com/vbulletin/images/HVAC/FanSpeed/HighOff.png")));
FanSpeedLookupDictionary.Add(FanSpeed.HIGHOn, new MyInternalHVAC_FanSpeed_Class(_digitalOutputPort_f or_fan_highon, FGLO_Texture.MakeQuickFGLOTexture___ConvertFromExt ernalImagePath("HVAC_Fan_Control___FanSpeedImage__ _HIGHON", "http://www.mp3car.com/vbulletin/images/HVAC/FanSpeed/HighOn.png")));
// Hook into when the FGLO is pressed
displayFuseGL_Object_for_fan_speed.MouseEvent___Cl ickDown += new FuseGL_Object.FuseGL_FGLO_MouseEvent(ChangeHVAC_Fa nSpeed_Button_Was_Pressed);
// Change the image to something known to begin with
ChangeFanSpeed(currentFanSpeed, displayFuseGL_Object_for_fan_speed);
void ChangeHVAC_FanSpeed_Button_Was_Pressed(object sender, FuseGL.FuseGL_GUI.MouseEventInformation MouseInfo)
switch(currentFanSpeed)
case FanSpeed.OFF:
currentFanSpeed = FanSpeed.LOW;
break;
case FanSpeed.LOW:
currentFanSpeed = FanSpeed.MEDIUM;
break;
case FanSpeed.MEDIUM:
currentFanSpeed = FanSpeed.HIGH;
break;
case FanSpeed.HIGH:
break;
ChangeFanSpeed(currentFanSpeed, (FuseGL.GUI.FuseGL_Object)sender);
public void ChangeFanSpeed(FanSpeed _speed, FuseGL.GUI.FuseGL_Object fanSpeedFGLO = null)
// Put some info in the trace for debugging perhaps?
FuseGL.FuseGL_Debugger.Trace.Add("Changing Fan Speed to: " + _speed);
// First turn off all the outputs
foreach(KeyValuePair<FanSpeed, MyInternalHVAC_FanSpeed_Class> aFanSpeed in FanSpeedLookupDictionary)
aFanSpeed.Value.DigitalOutputPort.Value = FB_Monitor.DigitalOutputPort.DIGITAL_OUTPUT_OFF;
// Then if it is a valid fan speed and the dictionary has been setup properly...
if(FanSpeedLookupDictionary.ContainsKey(_speed))
// Turn that output on
FanSpeedLookupDictionary[_speed].DigitalOutputPort.Value = FB_Monitor.DigitalOutputPort.DIGITAL_OUTPUT_ON;
// If the FGLO to display a picture in is valid...
if (fanSpeedFGLO != null)
// Change the texture to the correct one depicting the new fan speed
fanSpeedFGLO.TextureIsBeingOverriddenAndControlled Externally = true;
fanSpeedFGLO.TextureToOverrideWith = FanSpeedLookupDictionary[_speed].FGLO_Texture;
return;
Um, not sure why it put the web address in for my image location, but its not pulling internet pics.
Can you post the cs file or put them in [ code ] tags. It is hard to read. You need to upload your images to a web hosting site like this: http://image-host.us/
The post the image in [ img ] tags.
Oh ok. Below are the images. and the code. the very bottom image is the overall look of my layout as a whole. I thought maybe you could get an idea of what I'm trying to do with that. Thanks for all your help! this is all very new to me, but I do want to learn how to do it.
Code:using System; using System.Collections.Generic; using System.Linq; using System.Text; using FB_USB_2011; using FuseGL.GUI; namespace HVAC_Example { public class HVAC_Example { public enum FanSpeed { OFF, LOWON, LOWOFF, MEDIUMLOWON, MEDIUMLOWOFF, MEDIUMHIGHON, MEDIUMHIGHOFF, HIGHON, HIGHOFF } internal class MyInternalHVAC_FanSpeed_Class { public FB_Monitor.DigitalOutputPort DigitalOutputPort; public FuseGL.GUI.FGLO_Texture FGLO_Texture; public MyInternalHVAC_FanSpeed_Class(FB_Monitor.DigitalOutputPort digitalOutputPort, FGLO_Texture fgloTexture) { DigitalOutputPort = digitalOutputPort; FGLO_Texture = fgloTexture; } } internal Dictionary<FanSpeed, MyInternalHVAC_FanSpeed_Class> FanSpeedLookupDictionary = new Dictionary<FanSpeed,MyInternalHVAC_FanSpeed_Class>(); internal FanSpeed currentFanSpeed = FanSpeed.OFF; public void setup_HVAC( FuseGL.GUI.FuseGL_Object displayFuseGL_Object_for_fan_speed, FB_Monitor.DigitalOutputPort _digitalOutputPort_for_fan_off, FB_Monitor.DigitalOutputPort _digitalOutputPort_for_fan_lowoff, FB_Monitor.DigitalOutputPort _digitalOutputPort_for_fan_lowon, FB_Monitor.DigitalOutputPort _digitalOutputPort_for_fan_mediumlowoff, FB_Monitor.DigitalOutputPort _digitalOutputPort_for_fan_mediumlowon, FB_Monitor.DigitalOutputPort _digitalOutputPort_for_fan_mediumhighoff, FB_Monitor.DigitalOutputPort _digitalOutputPort_for_fan_mediumhighon, FB_Monitor.DigitalOutputPort _digitalOutputPort_for_fan_highoff, FB_Monitor.DigitalOutputPort _digitalOutputPort_for_fan_highon ) { // Setup FanSpeed textures and ports FanSpeedLookupDictionary.Add(FanSpeed.OFF, new MyInternalHVAC_FanSpeed_Class(_digitalOutputPort_for_fan_off, FGLO_Texture.MakeQuickFGLOTexture___ConvertFromExternalImagePath("HVAC_Fan_Control___FanSpeedImage___OFF", "images/HVAC/FanSpeed/Off.png"))); FanSpeedLookupDictionary.Add(FanSpeed.LOWOFF, new MyInternalHVAC_FanSpeed_Class(_digitalOutputPort_for_fan_lowoff, FGLO_Texture.MakeQuickFGLOTexture___ConvertFromExternalImagePath("HVAC_Fan_Control___FanSpeedImage___LOWOFF", "images/HVAC/FanSpeed/LowOff.png"))); FanSpeedLookupDictionary.Add(FanSpeed.LOWON, new MyInternalHVAC_FanSpeed_Class(_digitalOutputPort_for_fan_lowon, FGLO_Texture.MakeQuickFGLOTexture___ConvertFromExternalImagePath("HVAC_Fan_Control___FanSpeedImage___LOWON", "images/HVAC/FanSpeed/LowOn.png"))); FanSpeedLookupDictionary.Add(FanSpeed.MEDIUMLOWOFF, new MyInternalHVAC_FanSpeed_Class(_digitalOutputPort_for_fan_mediumlowoff, FGLO_Texture.MakeQuickFGLOTexture___ConvertFromExternalImagePath("HVAC_Fan_Control___FanSpeedImage___MEDIUMLOWOFF", "images/HVAC/FanSpeed/MediumLowOff.png"))); FanSpeedLookupDictionary.Add(FanSpeed.MEDIUMLOWON, new MyInternalHVAC_FanSpeed_Class(_digitalOutputPort_for_fan_mediumlowon, FGLO_Texture.MakeQuickFGLOTexture___ConvertFromExternalImagePath("HVAC_Fan_Control___FanSpeedImage___MEDIUMLOWON", "images/HVAC/FanSpeed/MediumLowon.png"))); FanSpeedLookupDictionary.Add(FanSpeed.MEDIUMHIGHOFF, new MyInternalHVAC_FanSpeed_Class(_digitalOutputPort_for_fan_mediumhighoff, FGLO_Texture.MakeQuickFGLOTexture___ConvertFromExternalImagePath("HVAC_Fan_Control___FanSpeedImage___MEDIUMHIGHOFF", "images/HVAC/FanSpeed/MediumHighOff.png"))); FanSpeedLookupDictionary.Add(FanSpeed.MEDIUMHIGHON, new MyInternalHVAC_FanSpeed_Class(_digitalOutputPort_for_fan_mediumhighon, FGLO_Texture.MakeQuickFGLOTexture___ConvertFromExternalImagePath("HVAC_Fan_Control___FanSpeedImage___MEDIUMHIGHON", "images/HVAC/FanSpeed/MediumHighON.png"))); FanSpeedLookupDictionary.Add(FanSpeed.HIGHOFF, new MyInternalHVAC_FanSpeed_Class(_digitalOutputPort_for_fan_highoff, FGLO_Texture.MakeQuickFGLOTexture___ConvertFromExternalImagePath("HVAC_Fan_Control___FanSpeedImage___HIGHOFF", "images/HVAC/FanSpeed/HighOff.png"))); FanSpeedLookupDictionary.Add(FanSpeed.HIGHOn, new MyInternalHVAC_FanSpeed_Class(_digitalOutputPort_for_fan_highon, FGLO_Texture.MakeQuickFGLOTexture___ConvertFromExternalImagePath("HVAC_Fan_Control___FanSpeedImage___HIGHON", "images/HVAC/FanSpeed/HighOn.png"))); // Hook into when the FGLO is pressed displayFuseGL_Object_for_fan_speed.MouseEvent___ClickDown += new FuseGL_Object.FuseGL_FGLO_MouseEvent(ChangeHVAC_FanSpeed_Button_Was_Pressed); // Change the image to something known to begin with ChangeFanSpeed(currentFanSpeed, displayFuseGL_Object_for_fan_speed); } void ChangeHVAC_FanSpeed_Button_Was_Pressed(object sender, FuseGL.FuseGL_GUI.MouseEventInformation MouseInfo) { switch(currentFanSpeed) { case FanSpeed.LOWOFF: currentFanSpeed = FanSpeed.LOWON; break; } ChangeFanSpeed(currentFanSpeed, (FuseGL.GUI.FuseGL_Object)sender); } public void ChangeFanSpeed(FanSpeed _speed, FuseGL.GUI.FuseGL_Object fanSpeedFGLO = null) { // Put some info in the trace for debugging perhaps? FuseGL.FuseGL_Debugger.Trace.Add("Changing Fan Speed to: " + _speed); // First turn off all the outputs foreach(KeyValuePair<FanSpeed, MyInternalHVAC_FanSpeed_Class> aFanSpeed in FanSpeedLookupDictionary) { aFanSpeed.Value.DigitalOutputPort.Value = FB_Monitor.DigitalOutputPort.DIGITAL_OUTPUT_OFF; } // Then if it is a valid fan speed and the dictionary has been setup properly... if(FanSpeedLookupDictionary.ContainsKey(_speed)) { // Turn that output on FanSpeedLookupDictionary[_speed].DigitalOutputPort.Value = FB_Monitor.DigitalOutputPort.DIGITAL_OUTPUT_ON; // If the FGLO to display a picture in is valid... if (fanSpeedFGLO != null) { // Change the texture to the correct one depicting the new fan speed fanSpeedFGLO.TextureIsBeingOverriddenAndControlledExternally = true; fanSpeedFGLO.TextureToOverrideWith = FanSpeedLookupDictionary[_speed].FGLO_Texture; } } return; } } }
