Results 1 to 3 of 3
Thread: FB4 to mute headunit
    Jan 2009
    Did a search here and on google, and couldn't find what I was looking for, Putting a new setup in my present vehicle, the computer is going to be used basically for navigation, traffic, weather etc, and my present headunit, a pioneer unit for music, would like to use FB to mute the headunit thru the phone wire which just completes a ground, when the nav. speaks directions. Garmin Mobile PC. I thing I can use a input from the speaker to the FB and have it trigger a relay to ground the phone wire on the headunit. but not very good with programing, so kinda of lost on that, or am am lost all the way around with my idea. Any help or ideas would be great.
    Mar 2006
    Colorado, but Canadian!
    Quote Originally Posted by my87ss View Post
    Grounding the phone wire is easy. Connect it straight to the minus side of a FB output. When you turn the output on and off, it will ground that wire.
    Getting the output to turn on and off however will not be easy. Using the speaker into an input would require a filter of some kind and some sort of cap integrator to know when it is speaking. This will introduce lag time as well as this cap charges to make sure it is voice and not just noise. So you might miss the beginning part and that would be annoying.
    It is probably best to have a software control that detects when there is output to the speakers, and then flip the FB output.
    1.9in x 2.9in -- 47mm x 73mm
    Jan 2009
    Thanks 2K1, time to do some more research and see what I can come up with
  1. Know of a way to mute a car deck with 3.5mm output and no mute out?
    By Mysticle31 in forum General Hardware Discussion
    Last Post: 06-09-2009, 11:38 AM
  2. Little help with "BYIND;LINEMUTE;MUTE;Line<<MUTE;Line"
    By antonio_riq in forum Road Runner
    Last Post: 01-22-2007, 03:33 PM
  3. Mute Doesn't Mute on M10k?
    By LiquidKernel in forum Car Audio
    Last Post: 08-22-2006, 03:12 AM
  4. Headunit or not to headunit EPIA 13000
    By Philhop in forum Car Audio
    Last Post: 06-09-2006, 07:45 AM
  5. how to mute sound with carkit without headunit
    By whocarez in forum Input Devices
    Last Post: 08-13-2003, 11:15 PM
