Page 2 of 2 FirstFirst 12
Results 11 to 18 of 18
Thread: Can Arduino sensors be used with the FB v6?
  1. #11
    Maximum Bitrate Dave One's Avatar
    Mar 2005
    Norfolk UK
    Quote Originally Posted by 2k1Toaster View Post
    Yes the inputs are 3.3v.
    And you won't get 3 equal signals on a 3-axis accelerometer when sitting there. You will get 1G in the Z direction and then hopefully 0G in the X and Y just from being idle.
    Good point. Thanks.
    Are there any neat ways to display the movements in RR?
    Cheers,
    Dave
    From my Sony Xperia
    Vauxhall Astra SXi Car PC installed.
  2. #12
    Mar 2005
    Norfolk UK
    Quote Originally Posted by settra View Post
    yiap.
    GS : the pin which allow's you to select sensitivity (1,5 or 6g). i think low input to that pin, is 1.5g , high is 6g.
    ST: is selft test. ignore it
    SL: sleep mode. in my accelometer, if this pin is not HIGH, it does not work... just sort it with VCC.
    OG: this pin is high, when all 3axis are sensing 0g.
    but dont take my word for it, becouse i can be making a mistake... ALL the information you need, can be found here:
    https://www.sparkfun.com/datasheets/...l/MMA7361L.pdf the datasheet for the chip, this sensor uses... (you anyway need it, to convert voltage to actual "g" )
    Just tried it out . Spot On, Cheers.
    I just have the problem of zero-ing and noise reduction but I have seen a thread on this, so of I go to read it .
  3. #13
    May 2010
    Herákleion, Iraklion, Greece, Greece
  4. #14
    Mar 2005
    Norfolk UK
    X is reading virtually 0G (1.6v), Y is reading virtually 0G (1.6v) and Z is reading 0.4G (1.73v) when held level. I was expecting Z to be 1G so I need to do some reading up.......... Enjoying learning what the Brain can do .
  5. #15
    May 2010
    well, 1G is not actually correct anyway. and depending on the design of the sensor, there could be good reasons why its not showing 1G.... there are some other force's , because of earth's rotation, that in macroscopic level don't seem important, but they could affect the sensors readings... but again, you do not care about the "Actuall" force that the sensor is sensing. only the difference in output, in regards to "Zero". i would, just use the "1.73v" as 0G...
    (the 1.6 v on X and Y, are there becouse there ARE forces on those axis too. but they are constant, like gravity, so you should not care, hence the "virtuall zero" )
  6. #16
    Mar 2005
    Norfolk UK
    I was thinking along similar lines about calling straight and level readings as 0 .
    What app are you using to display the data?
    Cheers,
    Dave
    From my Sony Xperia
  7. #17
    May 2010
    e well... i print through serial, all the info i want (Fuel, speed, accel), and then, have a a tablet, mounted as speedometer. i have written an app, to simulate a speedometer, but i dont know , any of-the-shelf solution.. :/
  8. #18
    Oct 2014
    I'm new to FB so my answer is more directed at how microcontrollers (MCs) generally work - First, most (not all) flavors of Arduino are 5v and the related sensors are the same - most MC's will not tolerate (i.e. they can burn up) voltage higher than their control voltage AND when using lower volt sensors you lose around 30% of the sensor 'resolution' - that said, as I understand it the FB is substantially more tolerant of mismatch voltages, but in order to get the most out of your sensor and, by proxy out of your FB I would recommend using a signal voltage adapter - this is sold as a 'Logic Level Converter'. Some are unidirectional and some are bidirectional so make sure to get one that matches your requirements.
    You could also get sensors that are the correct voltage - such as those for Raspberry PI and actually for a vast majority of MCs - Arudino's are an oddity in the sense that few MCs operate at 5v (or at least far less than operate at 3.3)
    Last bit of my 2 cents - most MC's, even if tolerant of higher-than-normal signal voltage will, when faced with 'out of spec' voltage, start acting unreliably and outputting a lot of 'garbage' readings - in other words, it is like if you turn your stereo up way louder than the speakers are designed for - they may survive but what you are listening to in the mean time is a lot of static, hisses and pops - i.e. not 'clean' sensor readings.
  1. Arduino PI?
    By Dave One in forum RR Plugins
    Last Post: 08-27-2015, 01:31 PM
  2. Arduino Uno Kit
    By SNOtwistR in forum Classifieds
    Last Post: 02-07-2014, 10:08 PM
  3. arduino to read car sensors
    By settra in forum Hardware Development
    Last Post: 11-01-2013, 07:03 PM
  4. Arduino as a touchscreen controller. Is it possible?
    By HiJackZX1 in forum General Hardware Discussion
    Last Post: 11-23-2012, 02:20 AM
  5. Arduino for OM - In progress
    By jmullan99 in forum OpenMobile
    Last Post: 03-13-2011, 05:43 PM
