Results 1 to 10 of 16
Thread: Help getting started please :)
    Maximum Bitrate Dave One's Avatar
    Mar 2005
    Norfolk UK
    Good morning all,
    I've got an FB v6 and have downloaded FuseGL from the FB site. Whenever I connect a temp sensor I get either -20.531 or -16.707 but nothing else. I have followed Grrrmachine's guide. It isn't that cold in my house so I know I'm doing something wrong. Ain0 is closest to the USB port isn't it, thus meaning Ain14 is furthest away? (although I put temp sensors on both anyway!)
    Any pointers? Any other guides/docs?
    I'm keen to get playing but have falling at the very first hurdle! I have some other projects that involve voltage monitoring which I would love to get sorted (accelerometer and steering angle sensor) too, so this isn't the best start.....
    Regards,
    Dave
    Vauxhall Astra SXi Car PC installed.
    Mar 2005
    Norfolk UK
    Any guides or documentation available?
    Mar 2006
    Colorado, but Canadian!
    Quote Originally Posted by Dave One View Post
    Good morning all,
    Regards,
    Dave
    Yes, AIN0 is the closest to the USB port.
    Quickest debug I can think of, have you been plugging it into the same port? FuseGL remembers what port you configure things to. What does the text file in the "FB Details" folder look like?
    1.9in x 2.9in -- 47mm x 73mm
    Mar 2005
    Norfolk UK
    Thanks for the reply. I know the FB has real potential for me, I just need to get my head around it ....
    I'm using the same port each time. I have a thermometer sensor on Ain0 and Ain14 and the sensor are -20.531 and -16.707 (or thereabouts) degrees centigrade.
    I have simply downloaded FuseGL and not added any variables or such like.....
    The text file in "FB Details" simply says:
    0|\\?\usb#vid_04d8&pid_fb60&mi_01#7&2ef8c1dc&0&000 1#{6813545a-53bc-4e52-a63f-77e5af150654}
    Cheers ,
    Dave
    Mar 2005
    Norfolk UK
    Does the text file highlight an obvious problem I can rectify? And is there any documentation to help me?
    Thanks in advance ,
    Dave
    From my Sony Xperia
    Mar 2006
    Just a quick stupid question, but are you sure the red wire goes to the "+" marks on the analogue inputs?
    Can you add a generic voltage sensor and see what it looks like? If you add a voltage sensor for all ports, or even temp for all ports, do they all show the wrong value, or does one pop up correctly?
    Cheers ,
    Dave
    That's good. It means there is only 1 instance so you are using the same physical USB port each time.
    Mar 2005
    Norfolk UK
    Nice one Nick . I set all analogue inputs in FuseGL as temp sensors as moved the temp sensor along one at a time to find that Ain0 (no change as stayed at -20.531) and Ain14 (change to -16.707). It appears that Ain0 and Ain14 unserviceable for whatever reason but I still have 13 analogue inputs to work with .
    Cheers
    Mar 2006
    Cheers
    If you just purchased it from me or MP3Car.com, we can swap it out if it has a bad port Dead On Arrival.
    Mar 2005
    Norfolk UK
    Quote Originally Posted by 2k1Toaster View Post
    It was bought from Grrrmachine on http://www.mp3car.com/classifieds/15...gps-mouse.html thread. Do you think it's worth re-installing the firmware?
    Cheers,
    Dave
    Mar 2006
    Cheers,
    Dave
    If everything is working except 2 ports, that sounds like a hardware problem not a firmware problem. Reinstalling the firmware doesn't hurt, but probably won't help.
  1. Getting Started
    By ssteger in forum VaultWiki
    Last Post: 10-19-2009, 03:54 PM
  2. Getting started with the Car PC
    By Heather in forum VaultWiki
    Last Post: 08-31-2009, 02:53 PM
  3. Help getting started
    By BMVEE in forum RR Skins
    Last Post: 05-22-2005, 01:44 AM
  4. Need help getting started
    By Tred in forum Newbie
    Last Post: 08-31-2004, 12:06 PM
  5. 1992 Maxima (just started, well ... just started progress)
    By arsalan_altaf in forum Show off your project
    Last Post: 10-18-2002, 03:55 PM
