Page 10 of 113 FirstFirst 123456789101112131415161718192060110 ... LastLast
Results 91 to 100 of 1124
Thread: *NEW* USB Input/Output Board -- Fusion Brain
  1. #91
    Mar 2006
    Colorado, but Canadian!
    Quote Originally Posted by Ruffy View Post
    poop i wasent selected as a beta tester.
    POOP I SAY!
    Sorry. We only have 6 board coming now to test them out. 1 for me, 1 for Tim, and 4 for betas.
    and @ redian: I have no clue what this is: !
    But maybe it can be our mascot!
    1.9in x 2.9in -- 47mm x 73mm
  2. #92
    Mar 2006
    Ok. I am putting the final "flare" on the software, and would like some input.
    What do you want the software to do based on conditions from the inputs?
    Right now button presses to applications, as well as change the state of an output are possible, but what else do you guys want?
    The button press pretty much encompasses everything, but I thought I could get some opinions.
    Here is your chance to chime in!
  3. #93
    Oct 2006
    Las Vegas
    Maybe timers. Like time delay relays. If you press a button it will stay on for X seconds or or wont activate for X seconds. outputs are tied to on_click events? What about triggering outputs to activate upon inputs, or combination of input and button, which could be mapped with software.
    It's been a while...
  4. #94
    Mar 2006
    I should also add, anything special in particular about the software maybe?
    As of now it can be skinned, log analoge input data and be externally controlled to put it simply. Of course the skinning includes options from changing the font on the buttons to the images to running hidden in the system tray.
    So suggestions?
  5. #95
    Variable Bitrate P3D4T0R's Avatar
    Dec 2006
    MA, USA
    Open source? A way to hack the firmware?
    "Mess with the best, die like the rest."
    Work Log --> Old Car (Totaled)
    Work Log v2 --> New Car (Totaled)
    Work Log v3 --> GMC Suburban K2500 (Work in progress)
  6. #96
    Oct 2006
    Las Vegas
    Trigger-able (alarm-like) events based on analog setpoint levels. For example, if battery voltage is low it could start the vehicle and recharge for either a prescribed time or voltage, assuming other prerequisites are met. Something that would allow a user to set something like that (or similar process) up. It'd be nice if the hardware had a wake-on-lan output for that however.
    But that takes some smarts (PIC-smarts, not badger smarts) Is there a controller?
  7. #97
    Mar 2006
    Quote Originally Posted by h3rk View Post
    Done. You can make it an "animation" with only 1 frame which would be on, and then have that frame repeat x amount of times. Each frame/iteration takes t seconds. t is user settable variable between 250ms and 1s which is the update frequency of the PIC. So if you want it on for 10 seconds then set 10/t is the number of iterations needed.
    Is this too complicated for people? I figured it would be very easy once people understand it...
    You mean the digital input is fooled into thinking that the button is being pressed for x seconds when it is really only being pressed momentarily? This could cause havoc in my eyes. Why out of curiosity?
    Not sure what you mean. Of course when you push the button for the digital output an onclick event is triggered and it changes the output next refresh cycle (250ms to 1s).
    The temperature, photocell, and potentiometer can all do this. I dont see a need for the accelerometer other than to flash "Slow the F down crazy man" after like 10g's.
    Interesting... Definately implementable... What would the benefit of this be though? That would mean a button only works if the analog input is within specs... So no volume control while the accelerometer reads more than x g's? I dunno.
    Good ideas. And I am not critisizing, I just want to see where the ideas lead. I am always interested in ideas!
    Quote Originally Posted by P3D4T0R View Post
    It will be open source.
    Hack the firmware? If you want, we shall add!
    But everything is done software side which is completely open source once we get it up and running.
    the PC must be on in order for the device to function. That way you dont have to shut it down when you leave. Neither of these are doable in the way you might want.
    If the PC is on, car is off, then yes it could theoretically start the car, but the PC will drain the battery by being on, so sort of a viscious circle!
    And the PIC makes no descisions such as interpretting a WOL signal. It only gets and sets the inputs and outputs and sends it to the PC to figure out. Sorry.
  8. #98
    Oct 2006
    Las Vegas
    Quote Originally Posted by 2k1Toaster View Post
    Right on!
    If the 'tied' output turns on with one press. The timer would cause it to turn off after set time. Possible use would be an actuator. It would prevent someone from having to use limit switches on their rocker-panel rocket launchers.
    Sweet.
    Safety interlocks. "you cant do this because you're not going Fast Enough" would be more my taste.
    All of my ideas can't be top-notch, but I have my moments. But I think you may know I'm not advertising all of them...yet. But you get to the good ones by blurting out all of the bad ones and getting them outta the way.
    ..I was thinking more like sending...
    But I understand, making smart I/O's with universal use in mind isn't the same.
    Oh and by the way I'd like to reserve a place in line for when they become available to the rest of us, if I may.
  9. #99
    Dec 2006
    MA, USA
    Sweet... Thank you.
    I was wondering for the outputs if there could be a "save state" and/or "default state" option. What I mean is when the computer is powered off the board will keep whatever state it was in but also be able to return to its default state if wanted. I dont know if that made sense, if it didn't ill fix it later.
  10. #100
    Oct 2006
    Las Vegas
    I like that idea. The each output could have two attributes like:
    .state.default=1
    .state.last=0
  1. Best mountable, DC powered USB Hubs?
    By Dan Marsh in forum General Hardware Discussion
    Last Post: 05-19-2010, 03:34 PM
  2. Via Epia Mii10000 USB
    By buurin in forum General Hardware Discussion
    Last Post: 07-22-2006, 03:52 PM
  3. Problem with ITPS / hibernation and External USB HD
    By veetid in forum Power Supplies
    Last Post: 01-02-2006, 09:35 PM
  4. Will this layout with a remote USB hub work?
    By NoPistonPC in forum General Hardware Discussion
    Last Post: 08-21-2005, 04:24 PM
  5. Replies: 4
    Last Post: 04-06-2004, 10:52 AM
