Page 101 of 113 FirstFirst ... 51919293949596979899100101102103104105106107108109110111 ... LastLast
Results 1,001 to 1,010 of 1124
Thread: *NEW* USB Input/Output Board -- Fusion Brain
  1. #1001
    Mar 2006
    Colorado, but Canadian!
    Quote Originally Posted by kostyanj View Post
    What if you constantly sample the state of the outputs? Then you could have as many instances of the program know about everything going on on the board.
    Yes you can do that, but I wont be doing it in the main program. Someone is working on a 3rd party dll to do just this.
    However the software should have full control over the hardware.For instance if it sends "turn on #1" you want it on. And if it is off you want it off. The program will overwirte the state of the outputs everytime to what they should be based on what the program knows. If a data stream is lost, and the software only sends once and polls, it wont get the message. Because the other instance of the program will get confused.
    Basically right now, the program will write what it believes to be true every time. And that wont change in the immediate future.
    1.9in x 2.9in -- 47mm x 73mm
  2. #1002
    Oct 2006
    Quote Originally Posted by 2k1Toaster View Post
    I haven't tried 2 instances of the program at the same time... Because they need the same dll, so 2 folders could and should do it.
    The only problem is if you were to change an output on program 1 program 2 wouldnt know about it. So now 1 would read on and the other would read off and who knows what the board would be!
    When I look into key commands, I will look into key commands for changing to specific pages. That way instead of opening 2 instances, you are just switching pages in the skin file.
    thats good to know! it wouldnt be a problem changing it in both folders anyway.
  3. #1003
    Aug 2006
    Thought I posted this once before, but I guess it didn't go through...
    I have been considering getting the Fusion Brain, so I've been brainstorming ideas that I could use it with... Let me know if these would be plausible.
    One thing that I know it can do and I like a lot is the automatic A/C controls and regulating the temp in the car. Just wanted to comment on that...
    I was curious, though: how many relays would it take to control a 3-knob A/C system?
    One idea I thought about would be to have a sensor that detected the outside temp and, when it was above a certain temperature, it would automatically lower the windows and moonroof. This would be a potential problem on the warm, rainy days... maybe a baro-sensor could work parallel to that? Or a manual override switch? I dunno... And, if that's possible, what about raising the volume on your PC when the windows go down to compensate for the noise of wind? And, if those are possible, if you have phone control, how about, when receiving a call, it reverses all of the above?
    Another feature, similar to that, would be to have it take some data from the GPS and you could log the coordinates of your house. That way, when you got within a certain range of home, it would know to roll up your windows/sunroof. Maybe this could also tap into the GPS program and be able to do it whenever going somewhere and approaching your destination...
    Also, how about auto-locks upon the car reaching a certain speed for those of us who don't have that feature built in already?
    Sorry for all the questions... I just have been thinking about this product a lot lately and would really like it if there was a way to perform the above.
    Thanks for any input!
  4. #1004
    Feb 2006
    most of those ideas sound good, except , having the auto-lock I CANT STAND
    . dont want it
  5. #1005
    Mar 2006
    Everything you mention is completely doable. The GPS and Phone Control however will require you or someone else writing custom interface software. In order for that functionality to be built in, I would need to write interfaces for all phones and all GPS programs. That would detract from the main purpose of the program and add unwanted bloat for many people.
    But yes it is possible.
  6. #1006
    FLAC FC3S's Avatar
    Jul 2006
    Seoul, Korea
    Quote Originally Posted by helllordkb View Post
    . dont want it
    if it autolocks above like 15km/h, and unlocks below 15km/h, then whats the problem, u like opening ur door at 50km/h?
    anyway, u could just not use it
  7. #1007
    pim
    pim is offline
    Mar 2006
    The Hague, the Netherlands
    I would buy this board for a single specific application:
    A Sony steering wheel adapter to Streetdeck input plugin.
    I have this Connect2 adapter that translates the factory specific steering wheel commands to the Sony wire resistance protocol. The analog input of the Fusion Brain should be able to decode the Sony protocol and generate input events to Streetdeck.
    I believe something similar exists for RoadRunner in combination with the Velleman kit.
    Doable? I'd pay for someone writing the plugin.
    Thanks,
    Pim
  8. #1008
    Mar 2006
    There is now a new version of the software available on the website. It added the rotation feature as well as some others. The skin designer is also updated. You can find them both here:
    http://www.fusioncontrolcentre.com/F...g/software.php
  9. #1009
    Mar 2006
    Quote Originally Posted by pim View Post
    Thanks,
    Pim
    Yes that is very doable. It would require you to change the resistive output to a voltage input scaled between 0 and 5 volts which is doable.
  10. #1010
    Variable Bitrate P3D4T0R's Avatar
    Dec 2006
    MA, USA
    I get an unexpected end of archive on both the zip and the rar download of the skin designer
    "Mess with the best, die like the rest."
    Work Log --> Old Car (Totaled)
    Work Log v2 --> New Car (Totaled)
    Work Log v3 --> GMC Suburban K2500 (Engine died)
    Work Log v4.5 --> 05 Toyota Tundra DC SR5
  1. Best mountable, DC powered USB Hubs?
    By Dan Marsh in forum General Hardware Discussion
    Last Post: 05-19-2010, 03:34 PM
  2. Via Epia Mii10000 USB
    By buurin in forum General Hardware Discussion
    Last Post: 07-22-2006, 03:52 PM
  3. Problem with ITPS / hibernation and External USB HD
    By veetid in forum Power Supplies
    Last Post: 01-02-2006, 09:35 PM
  4. Will this layout with a remote USB hub work?
    By NoPistonPC in forum General Hardware Discussion
    Last Post: 08-21-2005, 04:24 PM
  5. Replies: 4
    Last Post: 04-06-2004, 10:52 AM
