Page 102 of 113 FirstFirst ... 2529293949596979899100101102103104105106107108109110111112 ... LastLast
Results 1,011 to 1,020 of 1124
Thread: *NEW* USB Input/Output Board -- Fusion Brain
  1. #1011
    Mar 2006
    Colorado, but Canadian!
    Quote Originally Posted by P3D4T0R View Post
    I get an unexpected end of archive on both the zip and the rar download of the skin designer
    Just the skin designer?
    I'll re-upload them now
    1.9in x 2.9in -- 47mm x 73mm
  2. #1012
    Mar 2006
    Ok, I was able to reupload, then download and open, so they should work now. My connection has been flaky the past few days, so that might account for the file corruption.
  3. #1013
    Variable Bitrate P3D4T0R's Avatar
    Dec 2006
    MA, USA
    Quote Originally Posted by 2k1Toaster View Post
    Looks good now, thanks
    "Mess with the best, die like the rest."
    Work Log --> Old Car (Totaled)
    Work Log v2 --> New Car (Totaled)
    Work Log v3 --> GMC Suburban K2500 (Engine died)
    Work Log v4.5 --> 05 Toyota Tundra DC SR5
  4. #1014
    Jul 2007
    Thumbs up
    WooHoo. Finally powered up my Brain tonight and tested it with the lame skin I made. Iím using it in a Home Automation environment, not a CarPC. I donít have anything connected to the outputs yet, but the LEDs light up. I have a couple thermometers I connected to the analog inputs and tested that and it works. Yay!
    Iím really waiting for the COM interface so I can connect it to my HA software package. I havenít tested the latest software. Still running 1.5.1. Iíll upgrade later this week.
  5. #1015
    Jul 2007
    What are you planning on using that for? What are your final plans?
  6. #1016
    Jul 2007
    Iíll be using it with the rest of my Home Automation system, which controls lighting, irrigation, etc. Initially I will be using the Brain for the following:
    • Monitoring my garage doors: My main HA software (PowerHome) will poll the Brain (via a COM interface) to see if the doors are open. This is based on a dry contact switch (open/closed). I will write a rule for something like if itís after 6PM and a door is open, flash the keypad lights that are right by the entryway door. As Iím walking by, or when I pass by at night to go to bed, I will see that the doors are open and I can close them. (I donít want to close them automatically in case there is something (car) in the way.
    • Monitoring places for water (by my water heaters and washing machine): pretty much same as above. If water is detected, PH will send me a text message on my cell phone.
    • Monitoring occupancy: Use the Ultrasonic sensors and Temperature sensors to monitor if anyone is on the room. If not, turn off the HVAC in that part of the house. Possibly will use the outputs for this, to control the furnace.
    And Iím sure a whole slew of other things!
    For my lighting and irrigation control, I am currently using Insteon. Thereís a company that makes an Insteon compatible I/O controller, but it only has 2 inputs and 4 outputs (or vice versa) and costs $135. The Fusion Brain is less expensive and provides way more I/O ports and flexibility. Ok, Iíll have to write some software for it, but thatís Ok.
  7. #1017
    Aug 2007
    If i want to get down to the nity grity program end of things what do i need to learn?
    Would it be VB.net or something else?
  8. #1018
    Mar 2006
    It is is C#.NET and the source files as well as entire "project package" is releases on the website for Visual Studio 2005
  9. #1019
    Low Bitrate loginfailed's Avatar
    May 2007
    Texas
    Can this fusion brain do this?
    http://forums.fluxmedia.net/showpost...9&postcount=10
    Take a positive input and send out a keyboard command the once the positive input goes away, send out another different keyboard command?
    Mar 2006
    Quote Originally Posted by loginfailed View Post
    Yes absolutely. Very simple to setup and can be done 2 ways as well. As long as you know the Centrafuse hotkey.
    Spread the word over on the flux forums for us!
  1. Best mountable, DC powered USB Hubs?
    By Dan Marsh in forum General Hardware Discussion
    Last Post: 05-19-2010, 03:34 PM
  2. Via Epia Mii10000 USB
    By buurin in forum General Hardware Discussion
    Last Post: 07-22-2006, 03:52 PM
  3. Problem with ITPS / hibernation and External USB HD
    By veetid in forum Power Supplies
    Last Post: 01-02-2006, 09:35 PM
  4. Will this layout with a remote USB hub work?
    By NoPistonPC in forum General Hardware Discussion
    Last Post: 08-21-2005, 04:24 PM
  5. Replies: 4
    Last Post: 04-06-2004, 10:52 AM
