Page 103 of 113 FirstFirst ... 35393949596979899100101102103104105106107108109110111112 ... LastLast
Results 1,021 to 1,030 of 1124
Thread: *NEW* USB Input/Output Board -- Fusion Brain
  1. #1021
    Low Bitrate loginfailed's Avatar
    May 2007
    Texas
    Quote Originally Posted by 2k1Toaster View Post
    Yes absolutely. Very simple to setup and can be done 2 ways as well. As long as you know the Centrafuse hotkey.
    Spread the word over on the flux forums for us!
    I will let them know.
    So are these in stock ready to order?
    Also do you have any pics of all the sensors? On your store all it shows are generic icons..
  2. #1022
    Mar 2006
    Colorado, but Canadian!
    Quote Originally Posted by loginfailed View Post
    Its on the list for the sensor pics. I have had a few software compatability problems that I am trying to work through...
    I did post all the pictures but they were too bif for everyones browsers. If you want to look at them, here is the link though: http://www.fusioncontrolcentre.com/T...php?only=photo
    1.9in x 2.9in -- 47mm x 73mm
  3. #1023
    May 2007
    Texas
    Any chance of a Centrafuse plugin?
  4. #1024
    mezz64's Avatar
    Nov 2004
    PA
    Blog Entries
    1
    x2... integration would be nice, I'm just using the fusion software as a standalone at the moment.
  5. #1025
    Mar 2006
    Quote Originally Posted by mezz64 View Post
    It wont be top priority, but if there is enough interest rather than using the external application as embedded, then I will see what I can do.
    I wont be ableto get to it for a while though because there are quite a few other things going on I absolutely need to get done by next Monday...
    I am working on some compatability issues right now with the current software that has priority. I cannot test or run the program on my new machine due to it running on Vista and not XP. I cannot test or run anything because of the way drivers have changed. I have been working about 18hours a day specifically on this since I realized it, and I am not finished with it yet. I must completely re-write the driver as well as the entire way the device communicates through USB. I have re-written the driver, and it is recognized by Vista and XP, but now I must navigate the brand new WinUSB API to find how to send and receive data through the generic data pipes. To make everything worse, WinUSB has only been available since April, so documentation and examples are scarse to none.
    If anyones knows about or knows someone who knows about WinUSB_WritePipe and WinUSB_ReadPipe, let me know because this is where I am stuck at present. Today I was able to find the device and create a temporary handle for it, but any attempt to read or write data causes a memory error because something is pointed towards protected memory allocations... arrg.
  6. #1026
    Mar 2007
    manchester, UK
    good luck with this, your hard work is appreciated.
    just to let you know whilst you are working with winusb, i transferred to the car again, and it still didn't work. after trying several configurations, it does look like the issue is running it through a hub.
  7. #1027
    Mar 2006
    Well hopefully once I get this damned winusb thing sorted out, it wont matter if it is #127 in a USB daisy chain of hubs, because it will be working at the windows system level. The tradeoff is that it will be Vista native, and XP requires a co-installer for the dll. So the Vista driver is about 10kb, and the XP driver is about 50mb.
    But if I cant figure out how to write to the pipes, it doesnt really matter.
    I am asking some gurus on a different forum for help as well because this does have me baffled.
  8. #1028
    inh
    inh is offline
    Jan 2007
    Fort Riley KS
    50mb driver? no thanks...
    cashtexts - Earn money for receiving text messaged offers
    cashtexts review not a scam
    Space Navigator - 6 Axis input device: Take it apart - Driver App
    RRCam - Video/webcam capture, text overlay, and recording: 2.0 Stable
  9. #1029
    Mar 2006
    Quote Originally Posted by inh View Post
    There is no way around it. If you already have the WinUSB drivers installed, then you wont need the entire thing. WinUSB is a universal driver. So once you install it, you dont need it ever again even if your next printer uses them.
    The way USB works in Vista has pretty much completely changed under the hood and is causing pretty big headaches, but once it is done, it will be worth it.
  10. #1030
    Newbie mp3gtr's Avatar
    Apr 2007
    Birmingham, UK
    Any of the stuff at http://www.beyondlogic.org/ useful?
    Lots of USB info
  1. Best mountable, DC powered USB Hubs?
    By Dan Marsh in forum General Hardware Discussion
    Last Post: 05-19-2010, 03:34 PM
  2. Via Epia Mii10000 USB
    By buurin in forum General Hardware Discussion
    Last Post: 07-22-2006, 03:52 PM
  3. Problem with ITPS / hibernation and External USB HD
    By veetid in forum Power Supplies
    Last Post: 01-02-2006, 09:35 PM
  4. Will this layout with a remote USB hub work?
    By NoPistonPC in forum General Hardware Discussion
    Last Post: 08-21-2005, 04:24 PM
  5. Replies: 4
    Last Post: 04-06-2004, 10:52 AM
