from h3rk:
Oh and by the way I'd like to reserve a place in line for when they become available to the rest of us, if I may.
This is looking great! Thanks for all the work guys.
Already done!
Keep them coming!
done.
Not the last state, but default state is saved as can be referred to by pushing the big 'ol default button on the screen. It is also the state that is loaded when the app starts. So if you want your lights on when the board comes on, but not your 3gillion dB bullhorn, you can set that.
You beat me to it!![]()
1.9in x 2.9in -- 47mm x 73mm
Ok, I'm a little confused on the state saving part. If I were to say turn on output number 1, then shut down the computer, when I turn it back on will output 1 remain on? I'm pretty sure you've said yes to this but in your last post when you said "Not the last state", it threw me off a little.
Car : 00' Chrysler 300M
Speakers : Rainbow Audio SLC 265 | Subs : Diamond Audio D6 12" Subs X2
Amp's : Hifonics ZXi 6006 AB | Hifonics BXi 1606 D
CarPC: HP Laptop AMD Sempron 3000+ | 1.5GB RAM | DVD+RW | 80GB 5400RPM HD | ATI R200 Video
No it will not currently go to the last state it was in. It goes to the default state which you can set.
When you configure it all, you can choose which outputs you want high and which low as a default. Those are what are loaded when the program starts or when you click the default button.
Would it be better to make it the last state? All would be required is writing the current state to memory instead of just dumping it like it does now. That would require the program to be allowed read/write access after you push the close button.
What do you guys want?
Could it be made an option to choose between using the last state or the default state for an output? My main reason for wanting the last state is I would hope to use this to control a circuit to switch between a front/rear speaker setup and a front active setup, I'd like it to resume which ever configuration I had chosen when I shutdown, since the dsp configuration will load what was used last. If it were to revert the wrong way, I could accidentally send some nasty low frequencies through my tweeters and that would most certainly be bad.
Hmmm. Sure. Would you want something on the fly, or set through a config option and not to be seen again without opening another menu. So easy to go default/last state, or not so easy. Because the more stuff I put on the main screen, the more cluttered it becomes, and therefore not as TS friendly.
I could get away with some more buttons I think to toggle that... Shouldn't be too hard to implement.
