Page 112 of 113 FirstFirst ... 1262102103104105106107108109110111112113 LastLast
Results 1,111 to 1,120 of 1124
Thread: *NEW* USB Input/Output Board -- Fusion Brain
  1. #1111
    Mar 2009
    Quote Originally Posted by sporty_drew View Post
    HVAC- Heating, ventilating, and air conditioning.
    FB- Fusion Brain
    It uses relays for switching power.
    lol thanks,
    do u understand how fb can control a knob that i turn to increase or decrease my temperature in the car ?
    cheers
  2. #1112
    Maximum Bitrate sporty_drew's Avatar
    Mar 2006
    Iowa
    Have you checked out the Fusion Brain website? They have a lot of good information. How you will go about hooking it up to the car depends on your car.
    1998 Camaro Worklog Starting over, New setup for 2010
  3. #1113
    Mar 2009
    canbus elctrical system.
    car : seat leon mk2 ill look on their website, think ihave b4 but wasnt clear.
    i do not alot about electronics but just cant get any simple answeres from fb guys
  4. #1114
    Mar 2006
    Colorado, but Canadian!
    Quote Originally Posted by ellislake View Post
    Well I don't know what your electrical knowledge is. You are trying to tackle THE HARDEST possible automation that can be done in a car maybe apart from auto-pilot. And what makes it hard is that everyone is different.
    I don't mean they are all different as in laptops. Sure they are all "different", but underneath they all have the same parts just in different locations and grades of quality.
    HVAC systems are completely different. Take a tech that worked on X brand of car's HVAC his whole life and give him Y brand of car's HVAC, and most usually nothing will be familiar.
    Everything that clicks or pushes switches electricity somewhere to turn something on or off. A relay connected to a digital output does the same thing. You have to figure out where to put it. It is impossible for me to say "cut the red wire and put the relay between it and the flux capacitor". Every car is different. You should be familiar with electronics or at least have the patience to try it out before you attempt this. Every knob or dial that doesnt turn things on or off, but changes something that is already on, would be controlled by relays or PWM through MOSFETs. Anything you want as feedback like temperature or anything you want to display such as status of things, would connect to an input.
    1.9in x 2.9in -- 47mm x 73mm
  5. #1115
    Dec 2008
    i just dont really follow the benefits. any late model car has climate control, and works off a temp guage already. you will never make a pc setup thats as easy to use or as nearly reliable as an OEM system... im trying really hard to see the benefits of controlling your hvac with the carpc i just cant grasp the idea
  6. #1116
    Mar 2005
    Quote Originally Posted by trader007 View Post
    Some people want to put a screen where the controls are.
  7. #1117
    Newbie DANNYDOTNET's Avatar
    Aug 2009
    Like on a mobo can you make a fusion brain with a 4pin usb connector?
    Good Luck
    Follow me on twitter @Danny117
  8. #1118
    Aug 2009
    I've got one with dual zone automatic temperature but it doesn't do anything by voice. So instead of saying "turn up the heat" I have to go through the agony of pressing the temp button on the steering wheel.
    Good Luck
  9. #1119
    Dec 2008
    Quote Originally Posted by DANNYDOTNET View Post
    good point. it was dumb to say, its cool to even attempt this.
  10. #1120
    Jan 2007
    anyone know what voltage the digital input/outputs ports accept on a V4 board? not quite sure how to deal with them.
    any help appreciated
    thx phil
  1. Best mountable, DC powered USB Hubs?
    By Dan Marsh in forum General Hardware Discussion
    Last Post: 05-19-2010, 03:34 PM
  2. Via Epia Mii10000 USB
    By buurin in forum General Hardware Discussion
    Last Post: 07-22-2006, 03:52 PM
  3. Problem with ITPS / hibernation and External USB HD
    By veetid in forum Power Supplies
    Last Post: 01-02-2006, 09:35 PM
  4. Will this layout with a remote USB hub work?
    By NoPistonPC in forum General Hardware Discussion
    Last Post: 08-21-2005, 04:24 PM
  5. Replies: 4
    Last Post: 04-06-2004, 10:52 AM
