Page 12 of 113 FirstFirst ... 234567891011121314151617181920212262112 ... LastLast
Results 111 to 120 of 1124
Thread: *NEW* USB Input/Output Board -- Fusion Brain
  1. #111
    Oct 2006
    Las Vegas
    My vote is to keep the display as clean as possible. maybe a config page setting.
    It's been a while...
  2. #112
    Mar 2006
    Colorado, but Canadian!
    Quote Originally Posted by h3rk View Post
    Your wishes are my command.
    That will be a feature now. Well not, now but soon. Before release.
    1.9in x 2.9in -- 47mm x 73mm
  3. #113
    Nov 2006
    2k1Toaster,
    Do you think you could set the "last state" vs "default state" option per relay control? That'd please everyone, and also allow for some people to run some relays based on the default state and some on the last state.
    I know that complicates things a bit :P
  4. #114
    Mar 2006
    Quote Originally Posted by inFused View Post
    2k1Toaster,
    That's what the plan is.
    And I like your user name.
  5. #115
    Mar 2005
    Yeah, to restate the above:
    There will be two options for "saving state"
    Default - this is the value that automatically loads when the computer finishes starting up.
    Last known - this will maintain a value for as long as the PIC has power.
    I recognize that it would be nice to save the last known state into non-volatile RAM, but I need to look into whether the PIC has the ability to do that. I'm not sure.
  6. #116
    mezz64's Avatar
    Nov 2004
    PA
    Blog Entries
    1
    So the board will retain power once the engine is off, any idea of the current draw?
  7. #117
    Mar 2006
    Quote Originally Posted by greenman100 View Post
    I can make it software based but that would mean it will go to the last known state, only when the computer is on. So if output 1 is set to last known state as a default setting, and is on right when the computer shuts down, the output will shut off while the computer is off. Then once the computer and program start up again, it will go back to on with no user touch.
    We could set it through hardware, but like you said, that is constant power draw.
  8. #118
    Mar 2005
    Quote Originally Posted by mezz64 View Post
    Well it doesn't have to... it's up to you to maintain the last known state if you want. If you do, the drain of the board is about 20mA + whatever relays you use
    Alternatively, you can just let the PC hold the last state, and wait until it boots up... if that makes sense.
    We're still fleshing out the details... We'll do a full writeup once it's finalized.
    On another note, we got the beta boards today.
  9. #119
    Mar 2005
    We need to get a feel for how many people want accelerometers.
    The minimum order is 100, or pay a big setup fee for making the boards.
    The accelerometers would sell for $20, and be capable of measuring +/- 6g in any direction (triple axis)
  10. #120
    Mar 2006
    I want one! Do I count?
  1. Best mountable, DC powered USB Hubs?
    By Dan Marsh in forum General Hardware Discussion
    Last Post: 05-19-2010, 03:34 PM
  2. Via Epia Mii10000 USB
    By buurin in forum General Hardware Discussion
    Last Post: 07-22-2006, 03:52 PM
  3. Problem with ITPS / hibernation and External USB HD
    By veetid in forum Power Supplies
    Last Post: 01-02-2006, 09:35 PM
  4. Will this layout with a remote USB hub work?
    By NoPistonPC in forum General Hardware Discussion
    Last Post: 08-21-2005, 04:24 PM
  5. Replies: 4
    Last Post: 04-06-2004, 10:52 AM
