Page 14 of 113 FirstFirst ... 45678910111213141516171819202122232464 ... LastLast
Results 131 to 140 of 1124
Thread: *NEW* USB Input/Output Board -- Fusion Brain
  1. #131
    Mar 2006
    Colorado, but Canadian!
    Quote Originally Posted by P3D4T0R View Post
    Do you have anymore pictures of the actual board? Both in action and not.
    None in action, because they just arrived on my doorstep thisafternoon. I then took 1 out, and sent the rest to sunny Florida! Tim has the "Brain of Doom" as it is so labeled on the circuit. So they are pretty useless as is. But here are more non-in-action photos.
    And we got the gnome's approval as well.
    1.9in x 2.9in -- 47mm x 73mm
  2. #132
    Variable Bitrate P3D4T0R's Avatar
    Dec 2006
    MA, USA
    Quote Originally Posted by 2k1Toaster View Post
    Beautiful, that's just what I was looking for... AND you show measurements. This is going grate so far, I cant wait to get mine and test it out.
    "Mess with the best, die like the rest."
    Work Log --> Old Car (Totaled)
    Work Log v2 --> New Car (Totaled)
    Work Log v3 --> GMC Suburban K2500 (Work in progress)
  3. #133
    Mar 2006
    I have tons more and even higher resolutions photos if you want to see the lines in the copper!
    THey are 3.5Mb each.
  4. #134
    Dec 2006
    MA, USA
    Email them to me or I can give you an FTP site
  5. #135
    Dec 2005
    Sydney
    i want one!
    also if you cant write the last state into ram couldnt you just have a temp file to write/pull from that way even when u loose power there is something to go from. the only problrem with this is what happens if devices re-start after the car turns off/on? how will this syncronise with a temp file?
    I've also noticed that most of the config is done via the OSK. Would it be worthwhile letting it accept keyboard input aswell. That way it will make setup quicker when configuring prior to installing into the car...
    Also, how about an option to write values to a file. E.g. have the accelromoter running in the background and have it write the lowest/highest values at the end of each *variable* time preiod. The reson being so i can see what my mechanic gets up to when i leave the car there...
    What u think?
  6. #136
    Oct 2006
    Las Vegas
    So is this Fusion's first product? Do you guys do particle accellerators too?
    Do you have further plans? If so, what direction are you enviosioning moving from here?
    It's been a while...
  7. #137
    Mar 2005
    Quote Originally Posted by SmoL View Post
    i want one!
    What u think?
    The software already has the option to log and graph all analog data.
  8. #138
    Mar 2006
    i want one!
    Yes it writes to a file. It is not a temporary file, it is the config file. It automatically creates a backup of the lasy good config file upon a save. That way, if the computer crashes or hard power offs, while in the write state, the backup file can be restored.
    Not sure what you mean by devices restart after the car turns on/off. The PIC works like this for the most part:
    a) if there is a signal from the computer within a second or so, then it believes that the computer is on. Therefore pass the values it has to the outputs.
    b) if no signal is received, it assumes the computer is off, and all the outputs go low.
    So when the PIC is started, it makes all the outputs low, until a signal from the computer is received which contains the info it needs. Since you can power the PIC from anything between ~7v to 18v that means you can power the board from your cars unregulated voltage on a switched line to turn off the board completely when the car is off, or you can use a constant line. Either will work, and no advantage of one over the other.
    It is all done through the program, but that just writes to an ASCII based file called "UserConfig.atom". You may open it in Notepad and do whatever you please, all manually, but I must warn you now as well as the warning in the top of the config file... It is a very unforgiving file. You miss a colon ":" and the entire thing might fail at worst, or overwrite what you just did with the backup file because the one you made has errors.
    I DO NOT RECOMMEND MANUALLY EDITING THIS FILE!
    The entire config is meant to be really TS friendly for changing everything on the fly, and taking away the need for a keyboard. I even made my own OSK for it.
    Done
    Quote Originally Posted by h3rk View Post
    World domination.
  9. #139
    Oct 2006
    Las Vegas
    What u think?
    Done
    Like a datalogger?
    Wow, someone could maybe make a datalogger that takes inputs from obdII and enhance it to take inputs from your module(s) as well.
    World domination.
    Of course!
  10. #140
    Mar 2005
    Like a datalogger?
    Yes, exactly.
    So technically, you could tune something on your car, go give it a full throttle run, look at the data, export it to Excel, even, and then re-tune to see if you can manage better acceleration
  1. Best mountable, DC powered USB Hubs?
    By Dan Marsh in forum General Hardware Discussion
    Last Post: 05-19-2010, 03:34 PM
  2. Via Epia Mii10000 USB
    By buurin in forum General Hardware Discussion
    Last Post: 07-22-2006, 03:52 PM
  3. Problem with ITPS / hibernation and External USB HD
    By veetid in forum Power Supplies
    Last Post: 01-02-2006, 09:35 PM
  4. Will this layout with a remote USB hub work?
    By NoPistonPC in forum General Hardware Discussion
    Last Post: 08-21-2005, 04:24 PM
  5. Replies: 4
    Last Post: 04-06-2004, 10:52 AM
