Page 17 of 113 FirstFirst ... 78910111213141516171819202122232425262767 ... LastLast
Results 161 to 170 of 1124
Thread: *NEW* USB Input/Output Board -- Fusion Brain
  1. #161
    Maximum Bitrate Ruffy's Avatar
    Sep 2006
    Georgia
    You said a volume control is doable in the first post. You have got to sell an addon like the phidget encoder for this! Basic control that everyone and their mother needs.
    Car : 00' Chrysler 300M
    Speakers : Rainbow Audio SLC 265 | Subs : Diamond Audio D6 12" Subs X2
    Amp's : Hifonics ZXi 6006 AB | Hifonics BXi 1606 D
    CarPC: HP Laptop AMD Sempron 3000+ | 1.5GB RAM | DVD+RW | 80GB 5400RPM HD | ATI R200 Video
  2. #162
    Fusion Brain Creator
    Mar 2005
    Quote Originally Posted by Ruffy View Post
    We will have one, it will take up two inputs, either analog or digital, your choice. It will cost between 10 and 15 dollars. Probably June 2007.
  3. #163
    Oct 2006
    Las Vegas
    With a digital input, lets say that I have button I want to use to raise a parameter, like volume, by a value of 1. It would be nice if, by holding the button for 2 seconds the volume went up at a specified rate.
    With analog inputs lets say I have 3 I plan on using. For this example, temperature, voltage, and amps. It would be nice to have a group of settings I could use with that input to equate:
    (these example are rough and meaningless in nature to real applications)
    1. Temperature - 1V to 5V = 32F to 128F with settings for sensors with a positve or negative temperature coefficient.
    2. Voltage - .5V to 5.2V = 0V to 12V
    3. Amps - 20mV to 100mV = 1A to 15A
    So a control to select Units, and high and low equivalents, with a negative coefficient selection. Units, I guess would be string values.
    It's been a while...
  4. #164
    Mar 2006
    Colorado, but Canadian!
    Quote Originally Posted by h3rk View Post
    This will be coming, but is not done yet. This requires either parsing an equation or setting defalt values differently. The current temperature sensor we have is hard programmed in there for instance.
    It is expected to be done between beta testing and release.
    - Nick
    1.9in x 2.9in -- 47mm x 73mm
  5. #165
    Variable Bitrate P3D4T0R's Avatar
    Dec 2006
    MA, USA
    i was wondering about an update on the ETA of the boards (I really am impatient)... Also with the latest update to StreetDeck Iv had to ditch the program I was building, so I will probably try integrating the program strait into StreetDeck or use the DLL that Fusion Brain will provide... or something in between.
    "Mess with the best, die like the rest."
    Work Log --> Old Car (Totaled)
    Work Log v2 --> New Car (Totaled)
    Work Log v3 --> GMC Suburban K2500 (Work in progress)
  6. #166
    Mar 2005
    Quote Originally Posted by P3D4T0R View Post
    They should be in the mail sometime this week. We caught a few bugs already, and are working them out. Keep in mind this is a full product development from scratch... it takes time. We will post a video of it working later today.
  7. #167
    Dec 2006
    MA, USA
    Quote Originally Posted by greenman100 View Post
    I know how that goes... I built my own RFID kill switch for my car. I was just wondering how it was going plus I wanted to give an update on my side of things.
  8. #168
    Mar 2005
    Video:
    http://fusioncontrolcentre.com/alphatest2.mp4
    http://fusioncontrolcentre.com/alphatest2.avi
    Current status:
    Digital Outputs - all functional and tested
    Analog Inputs - all functional and tested
    Digital inputs - tested, needs minor change in firmware (<5 minutes) but I am away from my PIC programmer.
    so: The beta boards will be shipped this week for SURE. Then, we will have a beta period, likely a week or two.
  9. #169
    Mar 2005
    updated 4th post to reflect the above.
    please give Nick and I feedback on how we are doing. we are here to serve you. we can shift around priorities, work on different aspects. about all we can't change is the overall timeline... I know you guys want this immediately, but thousands of lines of code and hundreds of hours of research don't happen instantly.
  10. #170
    Oct 2004
    NY
    what's the easiest way to play an mp4?
  1. Best mountable, DC powered USB Hubs?
    By Dan Marsh in forum General Hardware Discussion
    Last Post: 05-19-2010, 03:34 PM
  2. Via Epia Mii10000 USB
    By buurin in forum General Hardware Discussion
    Last Post: 07-22-2006, 03:52 PM
  3. Problem with ITPS / hibernation and External USB HD
    By veetid in forum Power Supplies
    Last Post: 01-02-2006, 09:35 PM
  4. Will this layout with a remote USB hub work?
    By NoPistonPC in forum General Hardware Discussion
    Last Post: 08-21-2005, 04:24 PM
  5. Replies: 4
    Last Post: 04-06-2004, 10:52 AM
