Page 19 of 113 FirstFirst ... 9101112131415161718192021222324252627282969 ... LastLast
Results 181 to 190 of 1124
Thread: *NEW* USB Input/Output Board -- Fusion Brain
  1. #181
    Variable Bitrate Nerd2's Avatar
    Dec 2006
    Bristol/Cambridge, England
    Great thread this - sorry if i missed it in the 12 pages ( ), but any idea on shipping costs to europe? (uk?)
  2. #182
    Mar 2006
    Colorado, but Canadian!
    We will ship internationally, but you will have to pay VAT and the shipping...
    The overall weight is pretty light, so the shipping costs shouldn't be any different than what you would expect to pay for anything else shipped from the states to the EU.
    1.9in x 2.9in -- 47mm x 73mm
  3. #183
    Dec 2005
    Sydney
    is it possibler to make it so the user can choose between the LEDs being active or inactive. Just thinking it might get annoying with the lights if your trying to hide it somewhere under the dash... But i like the idea of LEDs for debugging
  4. #184
    Mar 2005
    Quote Originally Posted by P3D4T0R View Post
    It was just a thought for a feature... most LEDs run on 3.3v to 5v so running 12v to them is a pretty bad idea, I know of some LEDs that can run off of 12v but the are rare and expensive so I figured id throw the idea out there to see what you thought
    no, you have a great point...
    it's just that the trouble is the resistance value should change based on the number of LEDs per channel.... so what would we design it for? 1 LED? 2? 3?
    Does that make sense? It just seems like a feature that is limited in scope. Again though, we'll think about it.
  5. #185
    Mar 2005
    Quote Originally Posted by SmoL View Post
    great idea, and it should be settable with a jumper. how's that sound?
  6. #186
    Variable Bitrate P3D4T0R's Avatar
    Dec 2006
    MA, USA
    That sounds good
    "Mess with the best, die like the rest."
    Work Log --> Old Car (Totaled)
    Work Log v2 --> New Car (Totaled)
    Work Log v3 --> GMC Suburban K2500 (Work in progress)
  7. #187
    Maximum Bitrate NiSlo's Avatar
    Nov 2006
    Gold Coast, Australia
    I was just thinking, this could be used to solve the lilliput rear view cam auto-switch problem rather than using a stand alone pic system?
    Connect the reverse light wire to one of the inputs. When that becomes active, send a pulse (quick power on then off) to one of the outputs which is wired to the source switch button on the lilli. When the reverse light signal is lost, send two more pusles to get back to vga mode.
    Is there any reason that wouldn't work? Can the software be customised to do this?
    I installed my carpc into my pet Kangaroo, mate.
  8. #188
    Dec 2006
    MA, USA
    Quote Originally Posted by NiSlo View Post
    I haven't had an opportunity to test anything like this, and I may not be the best person to answer this question but from what I can tell from the hardware and the software it seems like it can and will work. I will let greenman100 or 2k1Toaster answer that for sure.
  9. #189
    Mar 2005
    That is very easy and is already pretty much in our software. So yes, it can happen, no problem.
  10. #190
    Mar 2006
    Quote Originally Posted by greenman100 View Post
    Yes this will be something that can be done fairly easily.
  1. Best mountable, DC powered USB Hubs?
    By Dan Marsh in forum General Hardware Discussion
    Last Post: 05-19-2010, 03:34 PM
  2. Via Epia Mii10000 USB
    By buurin in forum General Hardware Discussion
    Last Post: 07-22-2006, 03:52 PM
  3. Problem with ITPS / hibernation and External USB HD
    By veetid in forum Power Supplies
    Last Post: 01-02-2006, 09:35 PM
  4. Will this layout with a remote USB hub work?
    By NoPistonPC in forum General Hardware Discussion
    Last Post: 08-21-2005, 04:24 PM
  5. Replies: 4
    Last Post: 04-06-2004, 10:52 AM
