Page 21 of 113 FirstFirst ... 11121314151617181920212223242526272829303171 ... LastLast
Results 201 to 210 of 1124
Thread: *NEW* USB Input/Output Board -- Fusion Brain
  1. #201
    Fusion Brain Creator
    Mar 2005
    Beta guys:
    I have 5 assembled relays available.
    You can use the store to order these.
    Please do not hog them all. Remember there are 4 beta testers. I only have 5 relays.
    I will post once they're gone.
    Later tonight I will make a similar post for 6 temperature sensors.
  2. #202
    Mar 2005
    I also have 2 power jack available. I oly have two, so this is really meant for only the beta testers who can't get them on their own. Radioshack only had two, and I bought both.
    The jacks are free, but please don't take them if you don't need them. PM me if you do.
  3. #203
    Mar 2005
    5 Temperature sensors are finished and available. I will only have 5, not 6.
    I am attaching 5 pictures.
    1. Temperature Sensor
    2. Board with 5 relays and 5 temperature sensors.
    3. Board again
    4. Screenshot of our software running datalogging. This screenshot is flat, to show how there is no detectable noise or variation of signal. All the sensors are at the same temperature. Two of the sensors are different from the rest - these are a different model and have different response characteristics. Later tonight they will get hardcoded to read temperature rather than voltage.
    5. Screenshot of sensors reacting to heat. Each sensor is reacting differently because I aimed a hairdryer at the pile of sensors, so each is sensing a different temperature.... but it shows how the program plots data. The timescale is adjustable and is about 1 minute total for this screenshot.
    Go ahead and order through the store if you are a beta tester and want 1 or 2.
  4. #204
    Mar 2005
    Man, I am lighting up the boards tonight.... where is everyone else?
    Fusion Brain User Manual:
    http://fusioncontrolcentre.com/Fusio...r%20Manual.doc
  5. #205
    Oct 2006
    Las Vegas
    greenman100, you're making me wish I piped up about wanting to be a beta tester, also wishing I was chosen. I dig how well this appears to be coming along man.
    When obtaining your header connectors (I/O), did you see 90 degree females?
    Male 90's would be preferrable to me but those are kind of soldered on already.
    But, imho, if you're puting this in a shiny little black box, 90 deg. headers would be cleaner.
    (for more flat installations)
    It's been a while...
  6. #206
    Mar 2005
    We will certainly consider it for the final run.
  7. #207
    Maximum Bitrate Ruffy's Avatar
    Sep 2006
    Georgia
    I can always solder in 90degree connectors....... (I have a buttload of them)
    Car : 00' Chrysler 300M
    Speakers : Rainbow Audio SLC 265 | Subs : Diamond Audio D6 12" Subs X2
    Amp's : Hifonics ZXi 6006 AB | Hifonics BXi 1606 D
    CarPC: HP Laptop AMD Sempron 3000+ | 1.5GB RAM | DVD+RW | 80GB 5400RPM HD | ATI R200 Video
  8. #208
    Oct 2006
    Las Vegas
    I just don't care too much for hacking new stuff, if it can be avoided. And who knows, maybe they can find 90 degree header(s) that have the same output configuration, but require the connection points on the PCB to be in different places, etc.
  9. #209
    Oct 2004
    NY
    awe man, hacking up new stuff is where the fun begins
  10. #210
    Mar 2006
    Colorado, but Canadian!
    Wouldn't it be easier to hack the connectors on the sensors and outputs to be right angle female connectors, so the pins on the PCB are straight, and the female connectors are right angle. That way no soldering to the board, just some wire chopping.
    1.9in x 2.9in -- 47mm x 73mm
  1. Best mountable, DC powered USB Hubs?
    By Dan Marsh in forum General Hardware Discussion
    Last Post: 05-19-2010, 03:34 PM
  2. Via Epia Mii10000 USB
    By buurin in forum General Hardware Discussion
    Last Post: 07-22-2006, 03:52 PM
  3. Problem with ITPS / hibernation and External USB HD
    By veetid in forum Power Supplies
    Last Post: 01-02-2006, 09:35 PM
  4. Will this layout with a remote USB hub work?
    By NoPistonPC in forum General Hardware Discussion
    Last Post: 08-21-2005, 04:24 PM
  5. Replies: 4
    Last Post: 04-06-2004, 10:52 AM
