Page 26 of 113 FirstFirst ... 16171819202122232425262728293031323334353676 ... LastLast
Results 251 to 260 of 1124
Thread: *NEW* USB Input/Output Board -- Fusion Brain
  1. #251
    Variable Bitrate P3D4T0R's Avatar
    Dec 2006
    MA, USA
    I don't know what a magnetic sensor would be used for I'm just trying to through out possible ideas... as for the pressure sensor I could use one for each tire plus my coolant, my oil, gas, NOS, Boost, and whatever else I may want to measure pressure on in my car. I know most people wouldn't want to go to this kind of extreme, I probably wont because of the cost but it may be safe to say 100 could sell out easily.
    "Mess with the best, die like the rest."
    Work Log --> Old Car (Totaled)
    Work Log v2 --> New Car (Totaled)
    Work Log v3 --> GMC Suburban K2500 (Work in progress)
  2. #252
    Jul 2005
    i really need to have a pressure sensor that can read air pressure upto like 200psi, is there anything on the marlet to do this? and possible for u guys to implement?
  3. #253
    Dec 2006
    MA, USA
    Quote Originally Posted by Ryann View Post
    When it comes to something like that you might need to go custom and implement it yourself, this should get you started
    http://www.meas-spec.com/myMeas/down...p/MSP-5100.pdf
    http://www.omegadyne.com/ppt/prod.html?ref=PX6000-5V
    http://www.omega.com/pptst/PX102.html
    I may want something like this as well but I know not very many people will want something like this so I'm going my own way with it.
    P.S. It wont be cheap
  4. #254
    Fusion Brain Creator
    Mar 2005
    Yes.
    http://rocky.digikey.com/WebLib/Meas...a%20Stable.pdf
    But you're looking at about $70 a sensor.
  5. #255
    Jul 2005
    Well i know dakota uses these on there systems but i dunno if i could use them along with this. anyone know how these work?, they screw into a airline to get the pressure. and i guess send a resistance back?
    http://www.dakotadigital.com/index.c...rod/prd124.htm
  6. #256
    Mar 2005
    Those are nice! I'm sure I could configure it to work with our board, I may order one to play with it.
  7. #257
    Oct 2006
    Las Vegas
    Maybe a 'calibrate' function that prompts the user to set a condition like minimum pressure (0 psig) and then maximum pressure (xxx psig) and the program automatically sets the intercept and gain accordingly, automatically.
    It's been a while...
  8. #258
    Mar 2005
    Quote Originally Posted by h3rk View Post
    Good idea, but it will be rough if the sensor is non-linear
    users will have the ability to enter in curves for particular sensors, though
  9. #259
    Low Bitrate Rowan's Avatar
    Aug 2005
    Melbourne, Australia
    Hi, awesome project! Do you use HID or CNC? If HID, what bootloader do you use?
    May I suggest you place a diode before the input to the 7805 to protect against incorrect polarity? Also, do you have any decoupling caps for the AI's?
    Also, what is the current draw on the device? Since it is always on, even a couple hundred mA is quite a large parasitic load.. Perhaps use a 5v relay on the USB power to turn it on? Although, there goes 0mA load on the USB line. Or a p-channel mosfet? And that wouldn't work if USB is always powered.. Never mind, the easiest would be to power the device from the computers PSU.
    Holden VY Calais 5.7lt LS1 V8
    Computer:
    MB896 Pentium M Mini-ITX Motherboard, Intel Pentium M 750 1.86 GHz, 1Gb DDR2 Ram, 250GiB SATA, Xenarc 800TSV 8" VGA Monitor with touchscreen, GPS/Cellular/PCS/WiFi antenna, Bluetooth GPS, etc ,etc
  10. #260
    Mar 2005
    Quote Originally Posted by Rowan View Post
    CNC.
    The input on the final boards will be protected.
    Current draw is 55mA-110mA. It will be up to the end use to power it how they like... some people may want it to stay one contnuously, others may switch it with ignition.
  1. Best mountable, DC powered USB Hubs?
    By Dan Marsh in forum General Hardware Discussion
    Last Post: 05-19-2010, 03:34 PM
  2. Via Epia Mii10000 USB
    By buurin in forum General Hardware Discussion
    Last Post: 07-22-2006, 03:52 PM
  3. Problem with ITPS / hibernation and External USB HD
    By veetid in forum Power Supplies
    Last Post: 01-02-2006, 09:35 PM
  4. Will this layout with a remote USB hub work?
    By NoPistonPC in forum General Hardware Discussion
    Last Post: 08-21-2005, 04:24 PM
  5. Replies: 4
    Last Post: 04-06-2004, 10:52 AM
