Page 28 of 113 FirstFirst ... 18192021222324252627282930313233343536373878 ... LastLast
Results 271 to 280 of 1124
Thread: *NEW* USB Input/Output Board -- Fusion Brain
  1. #271
    Mar 2006
    Colorado, but Canadian!
    Who needs a driver.
    One sec, I'll find and post/edit this.
    1.9in x 2.9in -- 47mm x 73mm
  2. #272
    Variable Bitrate P3D4T0R's Avatar
    Dec 2006
    MA, USA
    Quote Originally Posted by 2k1Toaster View Post
    Who needs a driver.
    HAHA... Its a feature: Paperweight function
    "Mess with the best, die like the rest."
    Work Log --> Old Car (Totaled)
    Work Log v2 --> New Car (Totaled)
    Work Log v3 --> GMC Suburban K2500 (Work in progress)
  3. #273
    Oct 2004
    NY
    got mine too... soldering it up for my initial stuff is trivial, I guess I need software to to do anything with this too
  4. #274
    Mar 2006
  5. #275
    Mar 2006
    Quote Originally Posted by turbocad6 View Post
    Soldering!
    I guess you are the first Fusion hax0r!
  6. #276
    Oct 2004
    NY
    yeah man, instead of ordering all the headers & connectors & stuff I'll just solder it up, works for me
  7. #277
    Dec 2006
    MA, USA
    I found an interesting error in the board... Im not sure if this is the software of the brain but when I turn on DO#7 DO#8 turns off/will not go on. Two other things, as well. One, the board will disconnect and immediately reconnect to the computer; seems like a driver problem. When this happens if something is on it will turn off if its default is not set. Two, not sure if this is what its supposed to do but when defaults are set on a DO and the USB is disconnected (Simulating the computer being off) and the program is not set to defaults before this the board dose not return to default. <- This is what I meant by the feature request I made a while back.
    I forgot to mention that since I do not have my car right now I'm testing it on my home/work system which is running Vista which may explain some of the problems Im having.
  8. #278
    Mar 2005
    Quote Originally Posted by P3D4T0R View Post
    1. Some boards have bad LEDs. this is a QC issue we will try to work out with the PCB manufactur. Try putting your relay on the output and seeing if it responds. I remember two boards had bad LEDs.
    2. The board disconnecting/reconnecting is a particularly annoying issue, one I became aware of after I mailed the boards. Nick and I are working on this. It is hard to solve because it is so intermittent.
    3. Nick will respond to the default behavior.
    Thanks for working with us guys, there will be issues but we will mail you new PICs with updated firmware as I get them worked out.
  9. #279
    Dec 2006
    MA, USA
    Quote Originally Posted by greenman100 View Post
    1. This is what I thought at first but I tested it and with OD#7 and #8 on through software; #8 will be off (no power with volt meter) but if I turn #7 off, leaving #8 on, #8 will come on. This is repeated while turning #7 on and off.
    2. Aleast you know about it :shrug:
    3. ...
  10. #280
    Mar 2005
    I really need help on the disconnect/reconnect thing, guys. any bug reports or information you can give me would be appreciated. It is hard to troubleshoot because it is so intermittent. I've had the board go all night without disconnecting, and I've had it do it 3 times in 10 minutes.
  1. Best mountable, DC powered USB Hubs?
    By Dan Marsh in forum General Hardware Discussion
    Last Post: 05-19-2010, 03:34 PM
  2. Via Epia Mii10000 USB
    By buurin in forum General Hardware Discussion
    Last Post: 07-22-2006, 03:52 PM
  3. Problem with ITPS / hibernation and External USB HD
    By veetid in forum Power Supplies
    Last Post: 01-02-2006, 09:35 PM
  4. Will this layout with a remote USB hub work?
    By NoPistonPC in forum General Hardware Discussion
    Last Post: 08-21-2005, 04:24 PM
  5. Replies: 4
    Last Post: 04-06-2004, 10:52 AM
