1.9in x 2.9in -- 47mm x 73mm
"Mess with the best, die like the rest."
Work Log --> Old Car (Totaled)
Work Log v2 --> New Car (Totaled)
Work Log v3 --> GMC Suburban K2500 (Work in progress)
Unresolved Bugs
Fixed Bugs
Odd habit of connecting/disconnecting
Other Improvements
I have the timed turnoff working independently for each channel... in other words, you set each channel to turn off after x number of seconds.
If you have not paid for your relay and temp sensor, you need to.
Once everyone reports in with a day or two of experience, I will send out new firmware PICs. We will provide an envelope with postage.![]()
Ok, new update to the program: http://www.fusioncontrolcentre.com/S...2024-04-07.zip
Just replace the current *.exe with this one.
Changes for 24-04-07:
* Graphs now work again
* Took off protection timer for analogue timers. Now you can update at a theoretical 1mS interval. This is getting us around 17 kilobytes a second in data transfer. Which is more than enough resolution.
* Added some program protection.
More updates will come soon.![]()
Eh, got a package from santa in FL yesterday so i figured i would take some pics of it and share.
David
We should hire you to be our photographer!
I have updated the firmware.
Firmware Version 0.2 includes:
Fix - USB disconnect/reconnect
Fix - Analog 1/2 reversed
Added - Timer function for individual digital out channels
Changed - Theoretical Maximum Refresh rate from 32mS to 1mS
