Any other hardware bug reports? How are the sensors/relay working?
Those links are for the driver, main program with all the images and everything, and then the last exe is just to replace the current one in the first zipped file because it has some updates. It is a direct replacement.
I have another exe I am testing now that WILL NOT BE compatable with the userconfig.atom file, so with the newest exe hopefully coming in a day or two, you will either need to manually edit the userconfig.atom file to the correct string defaults, or delete those files, and redo the config. Just a heads up.
1.9in x 2.9in -- 47mm x 73mm
Well... I figured tonight since I wasn't tired I would work some more on this and while I was planning on how to mount it into my car I accidentally crossed to power wires and fried the voltage regulator. I was able to replace it with an equal alternative (non surface mounted) but I fear I may have fried the PIC because it is recognized by the computer but windows device manager says that the device has failed to start... I may be out of the beta testing before I could even really get a good test done on the software...![]()
"Mess with the best, die like the rest."
Work Log --> Old Car (Totaled)
Work Log v2 --> New Car (Totaled)
Work Log v3 --> GMC Suburban K2500 (Work in progress)
Holy crap!
Well we have version 2 of the firmware being shipped to you guys really soon. So you get a new PIC with that. You are supposed to return the old one, but we'll figure something out.
Now by crossing power wires, do you mean you hooked up the + to the - and visa versa, or did you just short some pins somewhere? We might be able to implement some protection...
Just to give some other stories too:
Both Tim and I have accidentally shorted the +12v to ground, and when I did it, my heart skipped a beat and the PIC shut off. Unplug/Replug and worked like a charm. I have accidentally shorted the +5v to ground, and same sort of thing. Then my board also fell off the table, did a George of the Jungle swing into the open +12v line from the hacked ATX PSU I am using. Nice spark and a black spot on the bottom of the board. Wiped it off, and it was all fine again afterwards.
So basically Tim and I have put these boards through hell, and they seem to work ok. Sorry for your bad luck...
Haven't been following lately but it seems this is a great product! Nice work!
Joachim
hey one thing i was wondering? maybe it could be added...
ok lets say output 1 (in my case will turn on supercharger) my system uses a electronic clutching system to activate/deactivate.
so say when you press "Supercharger" button an audio file opens *but doesn't interrupt what musics playing* and plays a WAV recorded something like "Supercharger Engaged Please Disengage Clutch Maintain Less Then 2 Thousand RPM" and lets say set a delay of 7 seconds, and lets say the recording was 7 seconds and at the last second it says "Engaged" and BOOM its on. after then when I Un-click it(turn it off), could it play another WAV file like "Supercharger disengaging, please disengage clutch and maintain low engine RPM's"
is this a feature anyone else would thinks cool?
Mobile Dynamics, *B.S.E Honors, Working On B.S.M.E* Audio Engineering Society Member, LKKR Kickboxing 3X Gold Medalist, IDSF Competitive Dance, Can-Fit Pro Personal Trainer Certified.
Ha, That nice to know for future reference but unfortunately for me it was + to - and - to + and I then that all to familiar smell of burning electronics (no smoke this time though). I tested with my multimeter on the voltage reg and it was giving out like 0.3v or something like that so i replaced it (Ill post a pic later). I took the PIC off to check to see if their was any damage to it and both the to and the underside appear fine with a slight smell of burnt electronics to it. So, I put it back on reapplied power and the USB and now my computer doesn't even see itI hope the new PIC's you send out fix this...
Well as long as you are still getting a nice 5v in, and the traces didn't melt or anything, it should be ok. You may have blown the LED's as well with that much reverse voltage, but they are in parallel to the outputs. So if you did blow an led, the actual relay drivers will still work. The relay driver chips (2 smd by the outputs, uln2003) should have enough protection for a short burst. But not a sustained reverse voltage.
Also the fuse on the board, may very well have just done its job, and heated up really high. It may not have though because I dont think it was meant to protect reversed, just excess... But try again tomorrow after it has a chance to cool off.
And while you are waiting for a new PIC, might as well, work on the software, or check the board for trace damage or something!
And please do answer Focal's question. Basically how many people want the ability to play custom sound files when a button is clicked? 1 for the ON state and 1 for the OFF state. Settable in the skin file?
Well I am off to bed, so goodnight everyone.
Oh, and I guess since both you and turbocad soldered onto the board, we need to know who did it first! Who was the first Fusion hacker?
Maybe I will make a portion of the website for "Hacked Brains" and you guys can post your picts of them.![]()
I personally probably wouldn't ever use something like that but I can see a valid reason for adding it plus the WOW factor, so Id say add it if its not to much trouble.
Originally Posted by 2k1Toaster
Not sure who was first, I guess I did my first soldering yesterday (04/24/2007) to fix that short in the leads. When did you start turbocad? Id be willing to bet you beat me... A section of the site with "Hacked Brains" would be sick, plus it would also make me want to hack it just to post pictures :P
