Page 35 of 113 FirstFirst ... 25262728293031323334353637383940414243444585 ... LastLast
Results 341 to 350 of 1124
Thread: *NEW* USB Input/Output Board -- Fusion Brain
  1. #341
    Mar 2006
    Colorado, but Canadian!
    Quote Originally Posted by turbocad6 View Post
    wow, that along with movable buttons should allow some nice skins, & with animated gifs, nice possibilities there for sure.... can't wait to see how that comes togeather.... is transparency supported?
    Hell ya transparency is supported! Actually it is pretty much required unelss you want all square buttons...
    1.9in x 2.9in -- 47mm x 73mm
  2. #342
    Mar 2006
    Ok, the next version of the software is ready enough to be distributed.
    I'll upload it in a bit along with a more detailed post of the new stuff, and stuff that has changed. As I said previously, THE USERCONFIG FILE IS NOT COMPATABLE WITH THIS NEW VERSION. So you will either have to manually convert it, or just start fresh. This is due to the added API calls to programs such as winamp and others that require a subclass to be specified along with a mainclass or mainwindow title.
    More details later.
  3. #343
    Mar 2006
    Here is the link:
    http://www.fusioncontrolcentre.com/S...a_25-04-07.zip
    No time right now to explain. I will try to tomorrow.
    Basically in the FusionForm.skin file:
    #ANIMATIONINTERVAL#250
    #ANALOGUEINTERVAL#50
    First is how fast the output channels update.
    The second is how fast the analogue channel updates.
    Both are in milliseconds. And no protection right now. If you enter "65t" it will error out.
    #AUDIOFROMOFFTOON#\Sounds\SampleClick.wav
    #AUDIOFROMONTOOFF#\Sounds\SampleClick.wav
    Under the digital out buttons 01 through 12 and all on/off.
    The file path of the audio file. Needs to be a *.wav and also no checking right now. So screw up, and who knows what infortuneate curse may be bestowed upon you. It uses window's API calling, so if you screw up, it screws up BIG TIME.
    Now in UserConfig.atom: This is the big reason you may not just copy the exe. You need to delete the current settings before you run or as soon as the digitial ins check, it will error out. here is why:
    >>DIGITAL IN 1
    All digital ins must now have 6 colons on the 3rd line. These are the delimeters for the sending keystrokes to windows through windows API. These are NOT TESTED right now. So reccommend you leave them alone right now. Just change the userconfig now so you dont have to later.
    Under the analogue input maps still in userconfig.atom:
    ##1
    >>MCP9701
    >>VOLTAGE
    >>C::(x-.4)*1000/19.5
    If you declare the 2nd area as VOLTAGE and it must be all caps, then the third line can have a custom function. For instance, 2 temp sensors went out with beta. MCP9700 and MCP9701. The MCP9700 is hardcoded into the "temperature". The MCP9701 is not. So that is the function for it in Celcius. The first part is the suffix for what it displays, then the MANDATORY delimeter of 2 colons, and then the function. Right now only simple. No errors can occur.
    Only "(,),*,/,+,-" and numerical digits and periods are allowed. Anything else, and you are playing with fire right now.
    Right now the above is only settable through the files, not through touchscreen. Frankly, I dont see the need for these to go in a touchscreen interface seeing as how once they are set, they are set sort of thing. One day they will go there but priority is low as of now. Pipe up if you disagree.
    More will come tomorrow/friday.
    And lastly, Enjoy.
  4. #344
    Jul 2005
    Quote Originally Posted by 2k1Toaster View Post
    Yes you can do it. Basically there are hidden buttons that are easy to access and retrieve data from in the application. So if you are good at programming, then go ahead.
    Well some people might feel better makit it themselves. I like my software obviously, but others may need some other functionality. Or maybe native into a custom frontend or something.
    Basically i wanted to make a complete hi graphic animated frontend.. no pred. it would not invlove recoding the whole thing at all.
    my plan is to run my entire airride system from it and maybe even my AC, power windows etc if i can get that far into it..
    all it would be is a wiz bang looking front end. much similir to the iPhone scheme i wanna emulate. that would retreive information from the fusionbrain software. and be able to operate the fusion software thru my frontend. rather then the fusion software directly.. In all aspects it would use the most of the software and all its coding.. all id be doing is some animated coding and forwarding to the powerful software. all credit to the fusion brainiacs.. im just the lil guy pulling info from it.
    my goal is to have a detailed 3d object with each side related to the airbag Pressure. and have the screen move in realtime to the way im driving and height. which isnt that hard if i could retreive the info from fusion software in realtime. get me?
    there is also plenty of exspansion to make some really good looking interface in flash. even have window animations to the relation of the window.. really endless opportunities..
  5. #345
    Mar 2006
    Quote Originally Posted by Ryann View Post
    Sounds pretty cool.
    Myself and a beta tester have worked closely getting the buttons to be externally readeable and controllable through API calls while the program is in the systemtray. I am not familiar how flash calls native OS functions, but I am sure it can be done.
    If you would like to release this software (as it sounds pretty sweet to me) we would love to have your controllable application in our donwload section on the website once you get it done, or beta. The actual download section is not even built yet!
    But yes you can read values from the buttons in realtime. Then parse your info from there. Also the buttons can all be pressed. If you look in the skin files, all the button's names are listed in there for each form in the app which should make identifying button titles really easy. There are also hidden buttons, for both analogue and digital incase you cannot access them directly. There have been changes to how the buttons are drawn recently, so these may not be needed anymore.
    We would need david to confirm this.
  6. #346
    Dec 2005
    Sydney
    instead of a wav file can we have wav and mp3? No real reason apart from just being stingy with my hard disk space
  7. #347
    Mar 2005
    Webdog, StealthRT, you guys need to send $10 for the relay and temp sensor....
  8. #348
    Variable Bitrate P3D4T0R's Avatar
    Dec 2006
    MA, USA
    Quote Originally Posted by greenman100 View Post
    Webdog, StealthRT, Predator, you guys need to send $10 for the relay and temp sensor....
    Sent
    "Mess with the best, die like the rest."
    Work Log --> Old Car (Totaled)
    Work Log v2 --> New Car (Totaled)
    Work Log v3 --> GMC Suburban K2500 (Work in progress)
  9. #349
    Mar 2006
    Quote Originally Posted by SmoL View Post
    Well playing mp3 requires using a codec, and that is pretty difficult for a small feature. And with multi-gagabyte harddrives, a couple more kb's wont kill ya!
    Ill look into seeing if I can do this easily. But I doubt it...
  10. #350
    Constant Bitrate Volsfan's Avatar
    Jan 2006
    Kingsport, TN
    I went ahead and ordered this unit through Paypal from your site.
    I realize that ya'll don't have an official ship date as of yet, however I hope that it was ok to go ahead and order it.
    BTW, always here to help beta test
    Tennessee Vols Fan
  1. Best mountable, DC powered USB Hubs?
    By Dan Marsh in forum General Hardware Discussion
    Last Post: 05-19-2010, 03:34 PM
  2. Via Epia Mii10000 USB
    By buurin in forum General Hardware Discussion
    Last Post: 07-22-2006, 03:52 PM
  3. Problem with ITPS / hibernation and External USB HD
    By veetid in forum Power Supplies
    Last Post: 01-02-2006, 09:35 PM
  4. Will this layout with a remote USB hub work?
    By NoPistonPC in forum General Hardware Discussion
    Last Post: 08-21-2005, 04:24 PM
  5. Replies: 4
    Last Post: 04-06-2004, 10:52 AM
