Page 38 of 113 FirstFirst ... 28293031323334353637383940414243444546474888 ... LastLast
Results 371 to 380 of 1124
Thread: *NEW* USB Input/Output Board -- Fusion Brain
  1. #371
    Fusion Brain Creator
    Mar 2005
    Quote Originally Posted by ukchris View Post
    greenman100 - Three months ago (January 26th) I paid you for some circuits you were going to build for me that might take "up to a month". Three months later you will not respond on AIM and I have heard nothing. I am obviously disappointed and do not know how else to contact you. Please let me know what the story is and/or refund my money ASAP.
    Chris.
    I tried to reply, but you had signed off, both times. I am happy to refund your payment, and the last time we talked, I offered this as an option, and you declined. You could have emailed me or Private Messaged me, of which you did neither. Please PM me and I will issue a refund to the account of your choice.
  2. #372
    Mar 2006
    Colorado, but Canadian!
    Ok, its been a long long night, but it comes with results!
    The new *.exe is a quick replacement for the old one. No full uninstall/reinstall needed. Just replace the old with the new and modify your skin files if you want the new features.
    Changes for todays release (all of which are in the FusionForm.skin file):
    1.) #ONLYSHOWANALOGUEORDIGITALNOTBOTH#true|false - If "true" then only the analogue buttons OR digital out buttons are displayed. So on the default BMV2-esque skin, you want this set to "true" or else you get a jumble of all the buttons at once. For skins where it is mostly graphical and you want the info from the analogues displayed on the same screen as the buttons for the digital outs, then set to "false".
    2.) #SIZE#x,y - Sets the size of the button to "x" pixels wide and "y" pixels high.
    3.) #LINKS#1;2;3 - Ties outputs together. Can only be used on the digital outs (duh... ) So this output when turned on will also turn on outputs 1, 2 and 3. When this output is turned off, it will turn off outputs 1, 2 and 3. Now the cool thing is that if output 2 or 3 is turned on or off, nothing special happens unless they too have a LINKS defined in their button area. Nifty eh? So this can be used for a custom "turn-on-some" button. I used one for testing with an animation of 4 frames. Each outputs had 1 frame on the rest off at different locations. Then I tied them all together so that the first was tied to the second, third, and fourth, and the second was tied to the first, third, and fourth and so on. Then when any of the 4 were clicked the animation started all at the same time, and without fail.
    4.) #MULTILEVELGRAPHICS##0,50#\Images\Thermometer\01.g if;\Images\Thermometer\02.gif;\Images\Thermometer\ 03.gif - Ok, this is a biggun. Basically you can add as many levels of accuracy as you want. Each image added is in the order of the first being the lowest and the last image on the line being tied to the highest value. Set the lowest and highest values in the second set of "#xx,yy#" parameters. The "0" in the example means 0 degrees and any value below 0C will show the first picture. The "50" means 50C and any value greater than 50C will show the last picture. Then a linear function is applied which is related to the max and min values as well as the number of images. So as the temperature increases from 0C to 50C, the pictures go up as well. Thanks to Turbocab for asking for this. It was evil to program and I am not certain all the bugs are out, but it is good enough for now. If you find bugs, as always, post and I will fix.
    5.) #SHOWTEXT#false|true - This is also only used for analogue inputs as of now. I guess I could do digital as well, but it isnt right now. For the default skin, this is set to "true". If going the graphical route, the text probably wont be wanted, so set it to "false".
    Ok, some things to note... Pay careful attention to what is delimitted by a semicolon, and what is delimitted by a comma. These are important. The skin file will error out if you miss these. Also on the end of the lines with the semicolon delimitting, such as the multi-image, DO NOT place a semicolon at the end of the line.
    And I think that is about it...
    http://www.fusioncontrolcentre.com/S...a_28-04-07.zip
    Ok in the zip file is the exe, and the included FusionForm skin has the new options in it so you can see them easily. To use that skin file unedited, just place the folder "Thermometer" inside your "Images" folder.
    1.9in x 2.9in -- 47mm x 73mm
  3. #373
    Mar 2006
    I just want to remember those who have downloaded the program, to please report what you like or dont like about it. Also what you would like to see in it. Any bug reports, anything. It works well on my computer, but that is not a good guarentee of all computers.
    Also has anybody tried to run the program on a via board? I sold my M10k, and now have a Pentium M which is actually the same as the laptop I am coding on, so it runs smooth as butter for me. Any lag issues on the via I should know about?
  4. #374
    Mar 2006
    Ok, just for grins and giggles I made the digital outs have no text as well.
    Just replace the exe with this again: http://www.fusioncontrolcentre.com/S...8-04-07_v2.zip
  5. #375
    FLAC ukchris's Avatar
    Nov 2003
    Massachusetts
    Quote Originally Posted by greenman100 View Post
    Similarly you could have PM'd, emailed or replied with an offline message with an update. Please refund directly to the same PayPal account, I'll PM you details in case you no longer have them.
    Chris.
  6. #376
    Mar 2005
    Chris.
    Done and Done.
  7. #377
    Oct 2004
    NY
    wow, digital outs & analog outs, both with no text, any image or animation & movable & resizable...
    that's friggin awsome...
    also the multiple images with auto scaling.... again, awsome..., then multiple timeouts for the same output, combining outputs, man... I gotta say it one more time, AWSOME!!!
    this is going to allow some really sick skins, taking the text away from the digital inputs will allow use of just a tiny indicator for some fuctions..., stupid question, but if it's selected to not show text, will this also apply to the configuration & settings screens? if it does it would be nice if there was a way to keep them, as the real eye candy is really only needed in the usage screen, but if not & it has to be global then skinning that isn't too big a deal either, well worth it for this kind of flexability...
    this is really shaping up to be one sweet interface...,
    today I wired the basics up & I am now able to lock & unlock my car, start & shut it off, open & close the windows all from my laptop!!!!
    it works
    so far I haven't had any problems, but I haven't dug into the software & skinning yet, maybe I'll try to play some with this over the weekend..., I think I'm seeing the disconnect & reconnect problem cause I keep hearing the little bing_bing sound from windows that you hear when you plug & unplug a usb device...
    why are some of the leds red & some green?
    I have more things to post later, but I just wanted to report so far so good & it's all working & fuctional so far
  8. #378
    Oct 2004
    NY
    also, it'd be a good idea to put the latest links for the software & drivers up in the first or second post, this threads getting real long & it's a pain to find the downloads as there scattered throughout the thread, guess it's just 4 of us so far, but eventually it'll need to be done anyway I think..
    oh yeah, did I mention?... AWSOME!!!
  9. #379
    Jul 2004
    Ohh! ohh! I have a feature that can be added to the list....
    Yep, u knew that was coming from me (again)
    David
  10. #380
    Variable Bitrate P3D4T0R's Avatar
    Dec 2006
    MA, USA
    Quote Originally Posted by StealthRT View Post
    David
    I like that idea... depending on how the PIC communicates with the PC adding bluetooth shouldn't be that hard. Simple serial protocol
    "Mess with the best, die like the rest."
    Work Log --> Old Car (Totaled)
    Work Log v2 --> New Car (Totaled)
    Work Log v3 --> GMC Suburban K2500 (Work in progress)
  1. Best mountable, DC powered USB Hubs?
    By Dan Marsh in forum General Hardware Discussion
    Last Post: 05-19-2010, 03:34 PM
  2. Via Epia Mii10000 USB
    By buurin in forum General Hardware Discussion
    Last Post: 07-22-2006, 03:52 PM
  3. Problem with ITPS / hibernation and External USB HD
    By veetid in forum Power Supplies
    Last Post: 01-02-2006, 09:35 PM
  4. Will this layout with a remote USB hub work?
    By NoPistonPC in forum General Hardware Discussion
    Last Post: 08-21-2005, 04:24 PM
  5. Replies: 4
    Last Post: 04-06-2004, 10:52 AM
